[QGIS-Developer] update of otb plugin for QGIS
Rashad Kanavath mohammedrashadkm at gmail.com
Tue Jan 30 01:14:58 PST 2018
Hell Tisham,
Can you explain the part of binaries issue?
The documentation of build from source is already there for OTB. The new
module which if merged into Modules/Wrappers/QGIS will be like any other
otb module.
Since there are no external dependencies, this could be enabled by default.
So need to specific documentation to build it is not required.
But once the coding work is done, there will be another (RFC) and in that i
will include the usage, builds options etc..
On Tue, Jan 30, 2018 at 1:10 AM, Tisham Dhar <tisham.dhar at aerometrex.com.au>
wrote:
> Hi All,
> I am an avid supporter to OTB and would love to see the plugin brought
> more in line with latest developments in OTB. The binaries issue will
> always exist and I believe OTB should support the same ones for which Qgis
> binaries are available already. The other platforms should have a clear
> build from source documentation. These should be listed in the RFC.
> Regards,
> Tisham Dhar
> Research Engineer
> Aerometrex PTY LTD
> 59 King William St.
> Kent Town SA 5067
> Australia
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Regards,
   Rashad
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180130/2c915c6b/attachment.html>
More information about the QGIS-Developer mailing list
