[QGIS-Developer] update of otb plugin for QGIS
Rashad Kanavath mohammedrashadkm at gmail.com
Wed Jan 31 00:49:11 PST 2018
Hello,
On Wed, Jan 31, 2018 at 2:05 AM, Tisham Dhar <tisham.dhar at aerometrex.com.au>
wrote:
> Hi Rashad,
> I meant pre-built OTB binaries rather than plugin binaries. I believe QGIS
> builds on more platforms than OTB does.
plugin code is in python. so nothing much to worry on binaries part and
they depend on qgis processing code.
QGIS had removed otb plugin from processing and kept others. So there is
another stuff to work on user side and developer side.
Regards,
> Tisham.
> *From:* Rashad Kanavath [mailto:mohammedrashadkm at gmail.com]
> *Sent:* Tuesday, January 30, 2018 7:45 PM
> *To:* Tisham Dhar <tisham.dhar at aerometrex.com.au>
> *Cc:* qgis-developer at lists.osgeo.org
> *Subject:* Re: [QGIS-Developer] update of otb plugin for QGIS
> Hell Tisham,
> Can you explain the part of binaries issue?
> The documentation of build from source is already there for OTB. The new
> module which if merged into Modules/Wrappers/QGIS will be like any other
> otb module.
> Since there are no external dependencies, this could be enabled by
> default. So need to specific documentation to build it is not required.
> But once the coding work is done, there will be another (RFC) and in that
> i will include the usage, builds options etc..
> On Tue, Jan 30, 2018 at 1:10 AM, Tisham Dhar <
> tisham.dhar at aerometrex.com.au> wrote:
> Hi All,
> I am an avid supporter to OTB and would love to see the plugin brought
> more in line with latest developments in OTB. The binaries issue will
> always exist and I believe OTB should support the same ones for which Qgis
> binaries are available already. The other platforms should have a clear
> build from source documentation. These should be listed in the RFC.
> Regards,
> Tisham Dhar
> Research Engineer
> Aerometrex PTY LTD
> 59 King William St.
> Kent Town SA 5067
> <https://maps.google.com/?q=59+King+William+St.%0D+%0D+Kent+Town+SA+5067%0D+Australia&entry=gmail&source=g>
> Australia
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Regards,
>    Rashad
Regards,
   Rashad
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180131/8e8d3789/attachment-0001.html>
More information about the QGIS-Developer mailing list
