[QGIS-Developer] Get rid of Processing scripts in favour of plain alogrithms
Victor Olaya volayaf at gmail.com
Wed Jan 31 01:05:31 PST 2018
Right, I see you your point.
I havent been able to follow the recent developments in Processing,
and i have to admit i am a little bit lost (Nyall has been working too
fast!!). So this is just my opinion, but it might not make sense in
the current situation.
I will try to get up to date as soon as possible :-)
Thanks for your collaboration!
2018-01-31 9:24 GMT+01:00 G. Allegri <giohappy at gmail.com>:
> I understand your point Victor, and I agree that scripts was a clever idea.
> But:
>  - with the current shape of Processing (QGIS 3.0) I think the "syntactic
> sugar" provided by scripts has less relevance. As I can see from the
> refactoring, there's less automation in parameters conversions and
> management, and a few new "magic" context variables have been introduced. I
> think scripts now are too similar to plain geoalgorithms, and consequently
> the differences can become misleading and not easily understood.
>  - syntactic sugar requires maintanance: if a new parameter is introduced, i
> parameters are added or changed, the corresponding translation method for
> scripts must be updated.
>  - syntactic sugar requires doc maintanance, while Processing APIs
> documentation can be mostly automated.
> Anyway, this is a proposal to be discussed. Meanwhile I will try to estimate
> the work needed to drop (and adapt) the current implementations.
> PS: @Victor, it's nice to follow Processing's history! C++ (SAGA) -> Java
> (Sextante) -> Python (Processing) -> C++ (QGIS 3.0)  :D
> All the best,
> Giovanni
> 2018-01-31 8:33 GMT+01:00 Victor Olaya <volayaf at gmail.com>:
>> I like the idea, but i dont think it will mean less code, specially
>> for defining the parameters and outputs. Why not keeping it for those
>> that want to use it this way?
>> Before removing this (in case it's decided to do so), two things to
>> notice:
>> -- There were algorithms (built-in ones) defined this way, so they
>> should be rewritten
>> -- There is a little-known functionality that creates a new plugin
>> from a set of scripts. It should be adapted as well, or removed.
>> Thanks!
>> 2018-01-30 21:41 GMT+01:00 G. Allegri <giohappy at gmail.com>:
>> > I know there are much more important priorities in view of the QGIS 3.0
>> > release.
>> > I will try to implement the idea of Geoalgorithms served by the script
>> > provider and, in case, I'll commit a PR for testing and comments.
>> > Giovanni
>> > Il 29 gen 2018 16:44, "Anita Graser" <anitagraser at gmx.at> ha scritto:
>> >> On Mon, Jan 29, 2018 at 2:24 PM, G. Allegri <giohappy at gmail.com> wrote:
>> >>> What's your opinion
>> >> 1 for me, as stated in the original thread
>> >> https://lists.osgeo.org/pipermail/qgis-developer/2018-January/051511.html
>> >> I think it will be good to unify the approaches.
>> >> Regards,
>> >> Anita
>> > _______________________________________________
>> > QGIS-Developer mailing list
>> > QGIS-Developer at lists.osgeo.org
>> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
