[QGIS-Developer] Issues building from source on Mac - No module named PyQt5
HernĂ¡n De Angelis
dhdeangelis at gmail.com
Fri Mar 9 07:14:02 PST 2018
Timur,
I am having similar issues in Linux openSUSE Leap 42.3. As far as I
understand there are issues and conflict between versions of PyQT and SIP.
It is not a QGIS problem. It would be nice to sort it out in any case.
/H.
On Thu, Mar 8, 2018 at 4:10 PM, Timur Girgin <girgin.timur at gmail.com> wrote:
> Hello everyone,
> I am having trouble building the QGIS release-3_0 branch on my Mac. I
> finally got it to cmake, however I am getting an error during the make
> process in which it seems that spatialite is using the system's Python(@2)
> executable to find PyQT5 when in reality it should be looking for it in the
> Python at 3 executable that has been given during CMAKE. I am guessing this
> is what is causing the issue.
> Please find the error at the bottom of this email. If anyone knows what I
> am doing wrong, would you please let me know?
> Thank you very much!
> Tim
> Here is my CMAKE:
> cmake -D CMAKE_INSTALL_PREFIX=~/Downloads/QGIS-build \
> -D CMAKE_BUILD_TYPE=MINSIZEREL -D ENABLE_TESTS=FALSE \
> -D SPATIALINDEX_LIBRARY=/usr/local/Cellar/spatialindex/1.8.5/lib/libspatialindex.4.dylib
> -D SPATIALINDEX_INCLUDE_DIR=/usr/local/Cellar/spatialindex/1.8.
> 5/include/spatialindex/\
> -D QWT_LIBRARY=/usr/local/qwt-6.1.3/lib/libqwt.dylib \
> -D QWT_INCLUDE_DIR=/usr/local/qwt-6.1.3/include \
> -D BISON_EXECUTABLE=/usr/local/Cellar/bison/3.0.4_1/bin/bison \
> -D GEOS_LIBRARY=/usr/local/Cellar/geos/3.6.2/lib/libgeos.dylib \
> -D GEOS_INCLUDE_DIR=/usr/local/Cellar/geos/3.6.2/include \
> -D LIBZIP_LIBRARY=/usr/local/Cellar/libzip/1.4.0/lib/libzip.5.0.dylib \
> -D LIBZIP_INCLUDE_DIR=/usr/local/Cellar/libzip/1.4.0/include \
> -D LIBZIP_CONF_INCLUDE_DIR=/usr/local/Cellar/libzip/1.4.0/include \
> -D EXPAT_LIBRARY=/usr/local/Cellar/expat/2.2.5/lib/libexpat.1.6.7.dylib
> -D EXPAT_INCLUDE_DIR=/usr/local/Cellar/expat/2.2.5/include \
> -D Qt5Core_DIR=/usr/local/Cellar/qt/5.10.1/lib/cmake/Qt5Core \
> -D Qt5Gui_DIR=/usr/local/Cellar/qt/5.10.1/lib/cmake/Qt5Gui \
> -D Qt5Test_DIR=/usr/local/Cellar/qt/5.10.1/lib/cmake/Qt5Test \
> -D Qt5Widgets_DIR=/usr/local/Cellar/qt/5.10.1/lib/cmake/Qt5Widgets \
> -D Qt5Concurrent_DIR=/usr/local/Cellar/qt/5.10.1/lib/cmake/Qt5Concurrent
> -D Qt5OpenGL_DIR=/usr/local/Cellar/qt/5.10.1/lib/cmake/Qt5OpenGL \
> -D Qt5Xml_DIR=/usr/local/Cellar/qt/5.10.1/lib/cmake/Qt5Xml \
> -D Qt5Svg_DIR=/usr/local/Cellar/qt/5.10.1/lib/cmake/Qt5Svg \
> -D Qt5Network_DIR=/usr/local/Cellar/qt/5.10.1/lib/cmake/Qt5Network \
> -D Qt5PrintSupport_DIR=/usr/local/Cellar/qt/5.10.1/lib/cmake/Qt5PrintSupport
> -D Qt5Positioning_DIR=/usr/local/Cellar/qt/5.10.1/lib/cmake/Qt5Positioning
> -D Qt5XmlPatterns_DIR=/usr/local/Cellar/qt/5.10.1/lib/cmake/Qt5XmlPatterns
> -D Qt5WebKit_DIR=/usr/local/Cellar/qt/5.10.1/lib/cmake/Qt5WebView \
> -D Qt5UiTools_DIR=/usr/local/Cellar/qt/5.10.1/lib/cmake/Qt5UiTools \
> -D Qt5Sql_DIR=/usr/local/Cellar/qt/5.10.1/lib/cmake/Qt5Sql \
> -D QCA_INCLUDE_DIR=/usr/local/Cellar/qt/5.10.1/lib/qca-qt5.
> framework/Versions/2.1.3/Headers \
> -D QCA_LIBRARY=/usr/local/Cellar/qt/5.10.1/lib/qca-qt5.
> framework/Versions/2.1.3/qca-qt5 \
> -D LIBTASN1_LIBRARY=/usr/local/Cellar/libtasn1/4.13/lib/libtasn1.6.dylib
> -D LIBTASN1_INCLUDE_DIR=/usr/local/Cellar/libtasn1/4.13/include \
> -D QSCINTILLA_INCLUDE_DIR=/usr/local/Cellar/qscintilla2/2.10.2_1/include
> -D QSCINTILLA_LIBRARY=/usr/local/Cellar/qscintilla2/2.10.2_1/
> lib/libqscintilla2_qt5.13.1.0.dylib \
> -D QTKEYCHAIN_INCLUDE_DIR=/usr/local/Cellar/qtkeychain/0.8.0/include \
> -D QTKEYCHAIN_LIBRARY=/usr/local/Cellar/qtkeychain/0.8.0/lib/libqt5keychain.0.8.0.dylib
> -D SPATIALITE_LIBRARY=/usr/local/Cellar/libspatialite/4.3.0a_6/lib/mod_spatialite.7.dylib
> -D SPATIALITE_INCLUDE_DIR=/usr/local/Cellar/libspatialite/4.3.0a_6/include
> -D SQLITE3_LIBRARY=/usr/local/Cellar/sqlite/3.22.0/lib/libsqlite3.0.dylib
> -D PYTHON_EXECUTABLE=/usr/local/bin/python3 \
> -D PYTHON_INCLUDE_PATH=/usr/local/Frameworks/Python.framework/Versions/3.6/Headers
> -D PYTHON_LIBRARY=/usr/local/Frameworks/Python.framework/Versions/3.6/Python
> -D WITH_QTWEBKIT=FALSE \
> Which outputs:
> -- QGIS version: 3.0.0 Girona (30000)
> -- Could not find GRASS 7
> -- Found Proj: /Library/Frameworks/PROJ.framework
> -- Found GEOS: /usr/local/Cellar/geos/3.6.2/lib/libgeos.dylib (3.6.2)
> -- Found GDAL: /usr/local/Cellar/gdal2/2.2.3/lib/libgdal.dylib (2.2.3)
> -- Found Expat: /usr/local/Cellar/expat/2.2.5/lib/libexpat.1.6.7.dylib
> -- Found Spatialindex: /usr/local/Cellar/spatialindex/1.8.5/lib/
> -- Found Qwt: /usr/local/qwt-6.1.3/lib/libqwt.dylib (6.1.3)
> -- Found libzip: /usr/local/Cellar/libzip/1.4.0/lib/libzip.5.0.dylib
> -- Found Sqlite3: /usr/local/Cellar/sqlite/3.22.0/lib/libsqlite3.0.dylib
> -- Found PostgreSQL: /usr/local/lib/libpq.dylib
> -- Found SpatiaLite: /usr/local/Cellar/libspatialite/4.3.0a_6/lib/
> -- Qt WebKit support DISABLED.
> -- Found Qt version: 5.10.1
> -- Found QScintilla2: /usr/local/Cellar/qscintilla2/
> 2.10.2_1/lib/libqscintilla2_qt5.13.1.0.dylib (2.10.2)
> -- Found QtKeychain: /usr/local/Cellar/qtkeychain/
> -- Found QCA: /usr/local/Cellar/qt/5.10.1/lib/qca-qt5.framework/Versions/2.1.3/qca-qt5
> (2.1.3)
> -- QtCore/QCA include/lib variables missing or CMake is cross-compiling,
> -- skipping QCA OpenSSL plugin C++ check
> -- Pedantic compiler settings enabled
> -- Found Python executable: /usr/local/bin/python3
> -- Found Python version: 3.6.4
> -- Found Python library: /usr/local/Frameworks/Python.
> -- Found Python site-packages: /usr/local/lib/python3.6/site-packages
> pyqt_version:050a01
> pyqt_version_num:330241
> pyqt_version_str:5.10.1
> pyqt_version_tag:
> pyqt_mod_dir:/usr/local/Cellar/python/3.6.4_3/Frameworks/Python.framework/
> Versions/3.6/lib/python3.6/site-packages/PyQt5
> pyqt_sip_dir:/usr/local/Cellar/python/3.6.4_3/Frameworks/Python.framework/
> Versions/3.6/share/sip
> pyqt_sip_flags:-t WS_MACX -t Qt_5_10_1
> pyqt_bin_dir:/usr/local/Cellar/python/3.6.4_3/Frameworks/Python.framework/
> Versions/3.6/bin
> -- Found PyQt5 version: 5.10.1
> -- Found SIP version: 4.19.8
> -- Found QScintilla2 PyQt module: 2.10.2
> -- txt2tags not found - disabled
> -- Found GSL: -L/usr/local/Cellar/gsl/2.4/lib -lgsl -lgslcblas
> -- Qsci sip file not found - disabling bindings for derived classes
> -- Configuring done
> -- Generating done
> -- Build files have been written to: /Users/tgirgin/Downloads/QGIS/build
> I added a MESSAGE to output the version and more of PyQt5, and it seems to
> be exactly where I expect it to be. However, during make it is being looked
> for using Python2.
> Output of make -j8:
> [ 9%] Built target zzz-MetaSearch-47-depend
> [ 9%] Built target zzz-MetaSearch-46-depend
> [ 9%] Built target zzz-MetaSearch-45-depend
> [ 9%] Generating resources_rc.py
> [ 9%] Built target zzz-db_manager-13-depend
> [ 9%] Built target pyutils
> [ 9%] Built target zzz-db_manager-12-depend
> /System/Library/Frameworks/Python.framework/Versions/2.7/
> Resources/Python.app/Contents/MacOS/Python: No module named PyQt5
> make[2]: *** [python/plugins/db_manager/resources_rc.py] Error 1
> make[1]: *** [python/plugins/db_manager/CMakeFiles/zzz-db_manager-14-depend.dir/all]
> Error 2
> make[1]: *** Waiting for unfinished jobs....
> [ 9%] Built target zzz-db_manager-2-depend
> [ 9%] Built target zzz-db_manager-6-depend
> [ 9%] Built target zzz-db_manager-4-depend
> make[2]: *** [python/plugins/db_manager/db_plugins/postgis/resources_rc.py]
> Error 1
> make[1]: *** [python/plugins/db_manager/db_plugins/postgis/CMakeFiles/
> zzz-db_manager-1-depend.dir/all] Error 2
> make: *** [all] Error 2
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180309/c7f85ee8/attachment-0001.html>
