[QGIS-Developer] Issues building from source on Mac - No module named PyQt5
Timur Girgin
girgin.timur at gmail.com
Fri Mar 9 08:22:39 PST 2018
Hello Carlo,
Would you advice building Qt5 from source then, rather than using brew?
Thanks
On Fri, Mar 9, 2018 at 11:13 AM, Carlo A. Bertelli (Charta s.r.l.) <
carlo.bertelli at gmail.com> wrote:
> Hello,
> I suggest to remind that using Homebrew carries in another issue. The
> maintainers decided to force everyone to use Qt5 as Qt4 is deprecated by Qt
> developers. Everything that was called qt5-something should become
> qt-something, so everyone who uses Qt4 had to make formulas called
> qt4-something for every Qt4 dependency.
> This was the case even for OsGeo4Mac (https://github.com/OsGeo/
> homebrew-osgeo4mac/) and Larry Shaffer had to recreate all the needed
> dependencies inside this tap. If you have old Qt dependencies inside your
> Homebrew, it may happen that qt-something is still qt4-something even if
> brew thinks it's qt5... Feeling bewildered? So am I.
> c
> On Thu, Mar 8, 2018 at 4:10 PM, Timur Girgin <girgin.timur at gmail.com>
> wrote:
>> Hello everyone,
>> I am having trouble building the QGIS release-3_0 branch on my Mac. I
>> finally got it to cmake, however I am getting an error during the make
>> process in which it seems that spatialite is using the system's Python(@2)
>> executable to find PyQT5 when in reality it should be looking for it in the
>> Python at 3 executable that has been given during CMAKE. I am guessing this
>> is what is causing the issue.
>> Please find the error at the bottom of this email. If anyone knows what I
>> am doing wrong, would you please let me know?
>> Thank you very much!
>> Tim
>> Here is my CMAKE:
>> cmake -D CMAKE_INSTALL_PREFIX=~/Downloads/QGIS-build \
>> -D CMAKE_BUILD_TYPE=MINSIZEREL -D ENABLE_TESTS=FALSE \
>> -D SPATIALINDEX_LIBRARY=/usr/local/Cellar/spatialindex/1.8.5/lib/libspatialindex.4.dylib
>> -D SPATIALINDEX_INCLUDE_DIR=/usr/local/Cellar/spatialindex/1.8.
>> 5/include/spatialindex/\
>> -D QWT_LIBRARY=/usr/local/qwt-6.1.3/lib/libqwt.dylib \
>> -D QWT_INCLUDE_DIR=/usr/local/qwt-6.1.3/include \
>> -D BISON_EXECUTABLE=/usr/local/Cellar/bison/3.0.4_1/bin/bison \
>> -D GEOS_LIBRARY=/usr/local/Cellar/geos/3.6.2/lib/libgeos.dylib \
>> -D GEOS_INCLUDE_DIR=/usr/local/Cellar/geos/3.6.2/include \
>> -D LIBZIP_LIBRARY=/usr/local/Cellar/libzip/1.4.0/lib/libzip.5.0.dylib \
>> -D LIBZIP_INCLUDE_DIR=/usr/local/Cellar/libzip/1.4.0/include \
>> -D LIBZIP_CONF_INCLUDE_DIR=/usr/local/Cellar/libzip/1.4.0/include \
>> -D EXPAT_LIBRARY=/usr/local/Cellar/expat/2.2.5/lib/libexpat.1.6.7.dylib
>> -D EXPAT_INCLUDE_DIR=/usr/local/Cellar/expat/2.2.5/include \
>> -D Qt5Core_DIR=/usr/local/Cellar/qt/5.10.1/lib/cmake/Qt5Core \
>> -D Qt5Gui_DIR=/usr/local/Cellar/qt/5.10.1/lib/cmake/Qt5Gui \
>> -D Qt5Test_DIR=/usr/local/Cellar/qt/5.10.1/lib/cmake/Qt5Test \
>> -D Qt5Widgets_DIR=/usr/local/Cellar/qt/5.10.1/lib/cmake/Qt5Widgets \
>> -D Qt5Concurrent_DIR=/usr/local/Cellar/qt/5.10.1/lib/cmake/Qt5Concurrent
>> -D Qt5OpenGL_DIR=/usr/local/Cellar/qt/5.10.1/lib/cmake/Qt5OpenGL \
>> -D Qt5Xml_DIR=/usr/local/Cellar/qt/5.10.1/lib/cmake/Qt5Xml \
>> -D Qt5Svg_DIR=/usr/local/Cellar/qt/5.10.1/lib/cmake/Qt5Svg \
>> -D Qt5Network_DIR=/usr/local/Cellar/qt/5.10.1/lib/cmake/Qt5Network \
>> -D Qt5PrintSupport_DIR=/usr/local/Cellar/qt/5.10.1/lib/cmake/Qt5PrintSupport
>> -D Qt5Positioning_DIR=/usr/local/Cellar/qt/5.10.1/lib/cmake/Qt5Positioning
>> -D Qt5XmlPatterns_DIR=/usr/local/Cellar/qt/5.10.1/lib/cmake/Qt5XmlPatterns
>> -D Qt5WebKit_DIR=/usr/local/Cellar/qt/5.10.1/lib/cmake/Qt5WebView \
>> -D Qt5UiTools_DIR=/usr/local/Cellar/qt/5.10.1/lib/cmake/Qt5UiTools \
>> -D Qt5Sql_DIR=/usr/local/Cellar/qt/5.10.1/lib/cmake/Qt5Sql \
>> -D QCA_INCLUDE_DIR=/usr/local/Cellar/qt/5.10.1/lib/qca-qt5.framework/Versions/2.1.3/Headers
>> -D QCA_LIBRARY=/usr/local/Cellar/qt/5.10.1/lib/qca-qt5.framework/Versions/2.1.3/qca-qt5
>> -D LIBTASN1_LIBRARY=/usr/local/Cellar/libtasn1/4.13/lib/libtasn1.6.dylib
>> -D LIBTASN1_INCLUDE_DIR=/usr/local/Cellar/libtasn1/4.13/include \
>> -D QSCINTILLA_INCLUDE_DIR=/usr/local/Cellar/qscintilla2/2.10.2_1/include
>> -D QSCINTILLA_LIBRARY=/usr/local/Cellar/qscintilla2/2.10.2_1/li
>> b/libqscintilla2_qt5.13.1.0.dylib \
>> -D QTKEYCHAIN_INCLUDE_DIR=/usr/local/Cellar/qtkeychain/0.8.0/include \
>> -D QTKEYCHAIN_LIBRARY=/usr/local/Cellar/qtkeychain/0.8.0/lib/libqt5keychain.0.8.0.dylib
>> -D SPATIALITE_LIBRARY=/usr/local/Cellar/libspatialite/4.3.0a_6/lib/mod_spatialite.7.dylib
>> -D SPATIALITE_INCLUDE_DIR=/usr/local/Cellar/libspatialite/4.3.0a_6/include
>> -D SQLITE3_LIBRARY=/usr/local/Cellar/sqlite/3.22.0/lib/libsqlite3.0.dylib
>> -D PYTHON_EXECUTABLE=/usr/local/bin/python3 \
>> -D PYTHON_INCLUDE_PATH=/usr/local/Frameworks/Python.framework/Versions/3.6/Headers
>> -D PYTHON_LIBRARY=/usr/local/Frameworks/Python.framework/Versions/3.6/Python
>> -D WITH_QTWEBKIT=FALSE \
>> Which outputs:
>> -- QGIS version: 3.0.0 Girona (30000)
>> -- Could not find GRASS 7
>> -- Found Proj: /Library/Frameworks/PROJ.framework
>> -- Found GEOS: /usr/local/Cellar/geos/3.6.2/lib/libgeos.dylib (3.6.2)
>> -- Found GDAL: /usr/local/Cellar/gdal2/2.2.3/lib/libgdal.dylib (2.2.3)
>> -- Found Expat: /usr/local/Cellar/expat/2.2.5/lib/libexpat.1.6.7.dylib
>> -- Found Spatialindex: /usr/local/Cellar/spatialindex
>> -- Found Qwt: /usr/local/qwt-6.1.3/lib/libqwt.dylib (6.1.3)
>> -- Found libzip: /usr/local/Cellar/libzip/1.4.0/lib/libzip.5.0.dylib
>> -- Found Sqlite3: /usr/local/Cellar/sqlite/3.22.0/lib/libsqlite3.0.dylib
>> -- Found PostgreSQL: /usr/local/lib/libpq.dylib
>> -- Found SpatiaLite: /usr/local/Cellar/libspatialit
>> -- Qt WebKit support DISABLED.
>> -- Found Qt version: 5.10.1
>> -- Found QScintilla2: /usr/local/Cellar/qscintilla2/
>> 2.10.2_1/lib/libqscintilla2_qt5.13.1.0.dylib (2.10.2)
>> -- Found QtKeychain: /usr/local/Cellar/qtkeychain/0
>> -- Found QCA: /usr/local/Cellar/qt/5.10.1/lib/qca-qt5.framework/Versions/2.1.3/qca-qt5
>> (2.1.3)
>> -- QtCore/QCA include/lib variables missing or CMake is cross-compiling,
>> -- skipping QCA OpenSSL plugin C++ check
>> -- Pedantic compiler settings enabled
>> -- Found Python executable: /usr/local/bin/python3
>> -- Found Python version: 3.6.4
>> -- Found Python library: /usr/local/Frameworks/Python.f
>> -- Found Python site-packages: /usr/local/lib/python3.6/site-packages
>> pyqt_version:050a01
>> pyqt_version_num:330241
>> pyqt_version_str:5.10.1
>> pyqt_version_tag:
>> pyqt_mod_dir:/usr/local/Cellar/python/3.6.4_3/Frameworks/
>> Python.framework/Versions/3.6/lib/python3.6/site-packages/PyQt5
>> pyqt_sip_dir:/usr/local/Cellar/python/3.6.4_3/Frameworks/
>> Python.framework/Versions/3.6/share/sip
>> pyqt_sip_flags:-t WS_MACX -t Qt_5_10_1
>> pyqt_bin_dir:/usr/local/Cellar/python/3.6.4_3/Frameworks/
>> Python.framework/Versions/3.6/bin
>> -- Found PyQt5 version: 5.10.1
>> -- Found SIP version: 4.19.8
>> -- Found QScintilla2 PyQt module: 2.10.2
>> -- txt2tags not found - disabled
>> -- Found GSL: -L/usr/local/Cellar/gsl/2.4/lib -lgsl -lgslcblas
>> -- Qsci sip file not found - disabling bindings for derived classes
>> -- Configuring done
>> -- Generating done
>> -- Build files have been written to: /Users/tgirgin/Downloads/QGIS/build
>> I added a MESSAGE to output the version and more of PyQt5, and it seems
>> to be exactly where I expect it to be. However, during make it is being
>> looked for using Python2.
>> Output of make -j8:
>> [ 9%] Built target zzz-MetaSearch-47-depend
>> [ 9%] Built target zzz-MetaSearch-46-depend
>> [ 9%] Built target zzz-MetaSearch-45-depend
>> [ 9%] Generating resources_rc.py
>> [ 9%] Built target zzz-db_manager-13-depend
>> [ 9%] Built target pyutils
>> [ 9%] Built target zzz-db_manager-12-depend
>> /System/Library/Frameworks/Python.framework/Versions/2.7/Res
>> ources/Python.app/Contents/MacOS/Python: No module named PyQt5
>> make[2]: *** [python/plugins/db_manager/resources_rc.py] Error 1
>> make[1]: *** [python/plugins/db_manager/CMakeFiles/zzz-db_manager-14-depend.dir/all]
>> Error 2
>> make[1]: *** Waiting for unfinished jobs....
>> [ 9%] Built target zzz-db_manager-2-depend
>> [ 9%] Built target zzz-db_manager-6-depend
>> [ 9%] Built target zzz-db_manager-4-depend
>> make[2]: *** [python/plugins/db_manager/db_plugins/postgis/resources_rc.py]
>> Error 1
>> make[1]: *** [python/plugins/db_manager/db_plugins/postgis/CMakeFiles/zzz-db_manager-1-depend.dir/all]
>> Error 2
>> make: *** [all] Error 2
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Carlo A. Bertelli
> Charta servizi e sistemi per il territorio e la storia ambientale srl
> Dipendenze del palazzo Doria,
> vc. alla Chiesa della Maddalena 9/2 16124 Genova (Italy)
> tel./fax +39(0)10 2475439 +39 0108566195
> <+39%20010%20856%206195> mobile:+39 393 1590711 <+39%20393%20159%200711>
> e-mail: bertelli at chartasrl.eu http://www.chartasrl.eu
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180309/3154cff8/attachment.html>
