[QGIS-Developer] $geometry does not consider changes in the edit uffer
Denis Rouzaud
denis.rouzaud at gmail.com
Fri Mar 16 05:51:47 PDT 2018
Hi Nyall,
Thanks for testing.
I tried again and still observe the issue.
I have found worst issues with setting this virtual fields with expression
"num_points( $geometry )"
- when adding a new feature and committing I get an error saying:
Feature has too many attributes (expecting 1, received 2)
although feature is correctly written to the provider
- the function seems to return actually 1 vertex more than there actually
is in the geometry
- I do need to commit to get the changes
I tested both with geopkg and shapefiles.
And I did not started alcohol yet today.
Cheers,
Denis
Le mar. 13 mars 2018 à 16:47, Nyall Dawson <nyall.dawson at gmail.com> a
écrit :
> On 14 March 2018 at 03:19, Denis Rouzaud <denis.rouzaud at gmail.com> wrote:
> > Hi again,
> > I'd like to bump this issue once more to the list....
> >> If I set a virtual field with the vertex count (i.e. num_points(
> >> $geometry ) ), it does not consider changes in the edit buffer.
> >> In other words, I have to commit the changes so the expression is
> correct.
> >> Is this an expected behavior?
> >> I would have expect to be updated directly.
> I can't reproduce -- it works fine here (testing through the attribute
> table).
> Nyall
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180316/6fc33b05/attachment.html>
