[QGIS-Developer] Set text of QgsLayoutItemLabel
SIGéal sigeal at sigeal.com
Sat Mar 17 04:32:30 PDT 2018
This thread might help you to find a workaround :
https://gis.stackexchange.com/questions/241213/how-to-get-a-composer-label-by-id-with-python-in-qgis
Christophe
Le 16/03/2018 à 16:56, KOHLMANN Hannes a écrit :
> Hello!
> I am facing difficulties trying to set the text of a  QgsLayoutItemLabel.
> I do something like the following to load a .qpt composer template and
> print this to a .png file (which works)
> path = "C:\\QGIS3\\apps\\qgis\\composer_templates"
> template_file = open(path+"\\ANSR_print_composer2.qpt")
> template_content = template_file.read()
> template_file.close()
> document = QDomDocument()
> document.setContent(template_content)
> composition = QgsLayout(QgsProject.instance())
> composition.loadFromTemplate(document, QgsReadWriteContext())
> map_item = composition.itemById('map')
> legend_item = composition.itemById('legend')
> text_item = composition.itemById('textbox')
> QgsLayoutExporter(composition).exportToImage( path+"\\report.png",
> QgsLayoutExporter.ImageExportSettings())
> And now I’d like to modify only the text of the QgsLayoutItemLabel,
> which is the “textbox”:
> 1)I can move it around with setX(), setY(), but I don’t know how to
> edit the text of the label. I thought of something like
> text_item.setText() or text_item.setLabelText(), but I think that
> text_item is just an instance of QgsLayoutItem, not
> QgsLayoutItemLabel. And there I get stuck.
> 2)How would you manually add another text label, set the main property
> etc, such that, at the end of the day, my above code would export a
> .png containing this QgsLayoutItem?
> I would have begun this way:
> new = QgsLayoutItemLabel(composition)
> new.setText(“New label”)
> But it does not quite work that way!
> Would be of great help, if you could give me some hints on that.
> Thank you in advance! J
> Hannes
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180317/4cb32648/attachment.html>
More information about the QGIS-Developer mailing list
