[QGIS-Developer] Custom widgets and Qt Designer 4 and 5
Matthias Kuhn matthias at opengis.ch
Tue Mar 20 03:46:16 PDT 2018
Hi matteo,
FYI, if you compile QGIS yourself anyway you don't need to compile it
against a custom GDAL version, you can also take the system one.
The error message you were seeing was only because the one you tried to
install (something ubuntugis I assume) was linked against a newer
version of gdal.
But you can of course also use the ones compiled against gdal 2.2.3, the
widgets won't look any newer though ;)
Cheers
Matthias
On 03/20/2018 11:32 AM, matteo wrote:
> Success!!
> Ok for those who can be interested, these are the steps I made:
> * download and compile gdal 2.2.3 (compiled in the /opt folder)
> * recompiled QGIS by changing the gdal paths and enable the flag WITH
> CUSTOMWIDGET
> * all went fine and QGIS is compiled against gdal 2.2.3
> * in the output/lib directory there is the libqgis_customwidgets.so and
> libqgis_customwidgets.so.3.1.0  files
> * I copied this files to  /usr/lib/x86_64-linux-gnu/qt5/plugins/designer/
> Q3 widgets are there. I still see they are saved with widget.h in the
> ui, so I guess one has to change the path manually or promote the widget
> like Etienne suggested
> Cheers
> Matteo
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
