[QGIS-Developer] What are "Key/value" and "List" widgets in attributes form?
Nyall Dawson nyall.dawson at gmail.com
Fri Mar 23 17:18:17 PDT 2018
On 23 March 2018 at 00:07, DelazJ <delazj at gmail.com> wrote:
> Hi all,
> In the vector layer properties dialog, Attributes form tab, I fail to
> understand/find what enables those two widgets, hence what they are supposed
> to do and how they could work.
> If someone has some information, thanks for sharing.
> Documenting this section is blocked by these information (see
> https://github.com/qgis/QGIS-Documentation/pull/2437/files)
I suspect these are only available for list/map field types - which as
far as I'm aware are only available for the postgres provider.
Nyall
> Thanks,
> Harrissou
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
