[QGIS-Developer] QGIS 3 on Ubuntu 17.10 uninstallable?
Patrick Dunford enzedrailmaps at gmail.com
Sun Mar 25 02:37:18 PDT 2018
These messages tell me this is an upgrade rather than a clean install.
Packages already installed on your system are of versions that can only
be upgraded to 3.1 (development release) because these existing packages
are a development release like 2.99 or 3.1. They do not install because
you have pointed apt at the stable repositories so they are not
available in those repositories.
If you have only uninstalled some packages you need to remove the ones
that are generating these error messages.
When you change repos the messages change because you are installing a
different version of Qgis and it needs different packages and apt will
still run into the same problem that the packages already in the system
are development release and can only be upgrade to another development
release and do not match the stable release.
Uninstall python-qgis, qgis-providers etc. Do an apt autoremove if there
is a list of packages that are no longer needed because it will probably
include a lot of qgis related packages.
On 25/03/18 21:36, Idan Miara wrote:
> Hi,
> I am trying to install QGIS Release / Nightly-Release on Ubuntu 17.10.
> I've added the repos:
> deb http://qgis.org/debian artful main
> deb-src http://qgis.org/debian artful main
> but I get the following error while trying to apt-get it:
> The following packages have unmet dependencies:
>  qgis : Depends: python-qgis (= 1:3.0.1+27artful) but
> 1:3.1.0+git20180323+4c4e8ac+27artful is to be installed
>         Depends: qgis-providers (= 1:3.0.1+27artful) but
>         Depends: qgis-common (= 1:3.0.1+27artful) but
>         Recommends: qgis-plugin-grass but it is not going to be installed
> E: Unable to correct problems, you have held broken packages.
> If I try the debian-nightly-release repo I get the following error:
>  qgis : Depends: python-qgis (= 1:3.0.0+git20180322+c312921+27artful)
> but 1:3.1.0+git20180323+4c4e8ac+27artful is to be installed
> 1:3.0.0+git20180322+c312921+27artful) but
>         Depends: qgis-common (= 1:3.0.0+git20180322+c312921+27artful)
> Kind Regards,
> Idan.
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180325/b2e06c2e/attachment.html>
More information about the QGIS-Developer mailing list
