[QGIS-Developer] RES: Esri Personal geodatabase (*.mdb)
Jorge Almerio jorgealmerio at yahoo.com.br
Thu May 10 10:07:35 PDT 2018
Thank you very much!!!
Please, Can anyone put this answer and close my bug report (https://issues.qgis.org/issues/18234)?
Can I put this answer at https://gis.stackexchange.com/questions/129514/opening-esri-personal-geodatabase-mdb-using-qgis/282387?noredirect=1#comment451561_282387 ?
Thanks again
-----Mensagem original-----
De: QGIS-Developer [mailto:qgis-developer-bounces at lists.osgeo.org] Em nome de andreaerdna
Enviada em: quinta-feira, 10 de maio de 2018 13:36
Para: qgis-developer at lists.osgeo.org
Assunto: Re: [QGIS-Developer] Esri Personal geodatabase (*.mdb)
andreaerdna wrote
> Therefore, to ensure that OGR_SKIP and PGEO_DRIVER_TEMPLATE are correctly
> set before QGIS 3 starts, you need to run qgis.bat (with the two line
> added).
and you can also, alternatively:
- set the two variables as User or System Windows Environment Variables (in
the Windows Advanced System Settings)
or
- set the two variables in QGIS through Settings -> Options | System |
Environment
The names and the values of the variables are:
variable name: OGR_SKIP
value: ODBC
variable name: PGEO_DRIVER_TEMPLATE
value: DRIVER=Microsoft Access Driver (*.mdb, *.accdb);DBQ=%s
note that there is only one percent sign in the value of
PGEO_DRIVER_TEMPLATE variable.
In both cases, you can launch QGIS normally through the Start Menu link.
Andrea Giudiceandrea
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-f4099106.html
QGIS-Developer mailing list
QGIS-Developer at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
