[QGIS-Developer] QGIS Server - SSL handshake failed for cascading WMS
Alessandro Pasotti apasotti at gmail.com
Mon May 14 08:49:06 PDT 2018
And this:
https://issues.qgis.org/issues/17951
and this too:
https://issues.qgis.org/issues/16462
On Mon, May 14, 2018 at 4:58 PM, Régis Haubourg <regis.haubourg at gmail.com>
wrote:
> Hi Anne,
> did you test QGIS 3.0 also?
> Could you create an issue in issue.qgis.org tracker?
> I found that one, that seemed related https://issues.qgis.org/issues/18634
> Regards,
> Régis
> 2018-05-14 16:25 GMT+02:00 Anne Blankert <anne.blankert at geodan.nl>:
>> Hello List,
>> This question was already asked in Jan 2017, but no solution was posted.
>> http://osgeo-org.1560.x6.nabble.com/QGIS-Server-SSL-handshak
>> e-failed-for-cascading-WMS-td5305094.html
>> The problem: if QGIS uses an HTTPS (SSL) WMS service, the WMS works
>> nicely in QGIS desktop. However, if you use the same .qgs project file on
>> QGIS Server, all requests to the HTTPS (SSL) WMS server result in an  SSL
>> handshake error.
>> This (still) happens on:
>> Ubuntu 16.04
>> QGIS server 2.18
>> An example WMS https server showing the problem is:
>> https://geodata.nationaalgeoregister.nl/bag/ows
>> A workaround could be to use the HTTP version of the WMS instead of the
>> HTTPS version. However, the capabilities of many HTTP services advertise
>> the HTTPS version for the GETMAP, GETFEATUREINFO and GETLEGENDGRAPHIC
>> endpoints.
>> The SSL problem also arises when trying to use WFS services over HTTPS
>> from QGIS Server.
>> Is this a known problem? Is there a workaround? Should I file a bug
>> report?
>> Thanks,
>> Anne
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Alessandro Pasotti
w3:   www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180514/2c16fbfa/attachment-0001.html>
More information about the QGIS-Developer mailing list
