[QGIS-Developer] Running qgis2to3 on windows
DelazJ delazj at gmail.com
Tue May 22 06:57:59 PDT 2018
Hi Tom,
Indeed, I should have read the help of the command; it mentions that. Using
a git infrastructure, I was surprised to see backup files as I could do a
reset if things went wrong but I guess the script is intended to be used in
any env.
Harrissou
2018-05-21 1:19 GMT+02:00 Tom Chadwin <tom.chadwin at nnpa.org.uk>:
> Those are likely to be your original Python 2 files, before the script made
> changes, allowing you to roll back. They should definitely not be
> published,
> but you should keep them yourself until you are confident the conversion
> was
> successful.
> Tom
> Buy Pie Spy: Adventures in British pastry 2010-11 on Amazon
> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-
> f4099106.html
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180522/9e3d54be/attachment.html>
More information about the QGIS-Developer mailing list
