[QGIS-Developer] Thoughts on using processing models for ETL tasks
Yves Jacolin yjacolin at free.fr
Mon May 28 03:50:34 PDT 2018
Hello,
Le 28/05/2018 à 12:11, johnrobot a écrit :
> - When creating a new model, I often need to run a model quite a few times
> to test it. Each time, I have to select input layers manually when starting
> the model. Can I make QGIS remember the files I picked the last time
In some ETL there is a concept of context parameters. It allows you to
setup parameters value for different context (dev, int, prod).
This feature could help also in your user case.
Y.
http://yjacolin.gloobe.org
Desc: OpenPGP digital signature
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180528/d977d938/attachment.sig>
More information about the QGIS-Developer mailing list
