[QGIS-Developer] Retrieve folder path from Processing scripts
matteo matteo.ghetta at gmail.com
Tue May 29 01:08:01 PDT 2018
Hi devs,
fighting with this problem I might have found a small bug (if someone
can confirm this).
So with `QgsProcessingParameterFolderDestination` and
`parameterAsString` Processing takes the path only if the path is added
manually OR if the user choose the path from the button BUT types
something in the box.
If the path is taken directly from the button I always get a temporary path
If someone wants to give a try I have prepared a copy/paste script for
testing here:
https://pastebin.com/DEHvD0nr
If confirmed I can open a ticket
Thanks
Matteo
More information about the QGIS-Developer mailing list
