[QGIS-Developer] qt5-qml library not installed per default used on runtime by the QML widget
Jürgen E. Fischer jef at norbit.de
Mon Nov 12 13:01:26 PST 2018
Hi David,
On Thu, 08. Nov 2018 at 10:12:17 +0100, David Signer wrote:
> After there has been some field-tests of the QML Widget, we recognized that
> the qt5-qml library used on runtime is not  installed per default.
> This is no problem doing it manually, but it would be more comfortable for
> users to have it per default?  Would that be possible?
On Thu, 08. Nov 2018 at 10:58:37 +0100, David Signer wrote:
> I forgot to precise that it's concerning Windows.
Meanwhile added as dependency to qgis/qgis-rel-dev/qgis-dev in OSGeo4W.
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden             http://www.norbit.de
QGIS release manager (PSC)  Germany                    IRC: jef on FreeNode
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20181112/7ad3809d/attachment.sig>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20181112/7ad3809d/attachment.ksh>
More information about the QGIS-Developer mailing list
