[QGIS-Developer] [GRASS-dev] Access to GRASS GIS addons
    Stefan Blumentrath
    Stefan.Blumentrath at nina.no
    Wed Oct 10 22:53:23 PDT 2018
Dear Nikos,
Approaches are a bit different for Processing and the GRASS plugin, though both do not allow usage of GRASS addons out-of-the-box.
Assuming you are aiming at integration in Processing have a look here:
https://gis.stackexchange.com/questions/150100/how-to-add-my-own-grass-algorithms-to-processing
and
https://github.com/qgis/QGIS/blob/b3d2619976a69d7fb67b884492da491dfaba287c/python/plugins/processing/algs/grass7/description/r.horizon.height.txt
on how you would have to tweak local GRASS and QGIS installation.
For less experienced users that are supposed to use the addon, you would probably want to write a little installation routine for your addon, that puts txt files into right places in the installation and also installs the GRASS addon systemwide...
Cheers
Stefan
-----Original Message-----
From: grass-dev <grass-dev-bounces at lists.osgeo.org> On Behalf Of Nikos Alexandris
Sent: onsdag 10. oktober 2018 17:45
To: qgis-developer at lists.osgeo.org
Cc: grass-dev at lists.osgeo.org
Subject: [GRASS-dev] Access to GRASS GIS addons
Dear QGIS developers,
I'd much appreciate some response in the following questions.
I rarely use Windows, yet I would like to learn about the latest status in accessing GRASS GIS addons (not only regular modules) through QGIS under Windows.
If I write an addon for GRASS GIS, can I then provide/ensure access to it for Windows users of QGIS?
Thank you, Nikos
