[QGIS-Developer] open atlas layout, using python
Raymond Nijssen r.nijssen at terglobo.nl
Thu Oct 11 09:21:54 PDT 2018
By the way, the fragile code solution does not work for me. It does
toggle the button but it does not activate the atlas preview.
# open layout
designer = iface.openLayoutDesigner(layout)
# turn on atlas preview mode
lo_view = designer.view()
lo_window = lo_view.window()
action = lo_window.findChild(QAction, 'mActionAtlasPreview')
action.toggle()
On 11-10-18 16:51, Raymond Nijssen wrote:
> Hi Nyall,
> It sounded great and I spent some hours on that better approach, but I
> didn't succeed. So maybe 3.6 will have it...
> Tnx!
> Raymond
> On 25-09-18 23:57, Nyall Dawson wrote:
>> On Tue, 25 Sep 2018 at 22:36, Raymond Nijssen <r.nijssen at terglobo.nl>
>> wrote:
>>> 1. Can I open a layout window with a python command?
>> designer = iface.openLayoutDesigner( layout )
>>> 2. Can I turn on "atlas preview" with a python command?
>> You'd have to do some fragile code to do this. Basically:
>> - get designer window from designer.view()'s parent window
>> - find the mActionAtlasPreview child action in the window
>> - manually toggle it on
>> This should work, but isn't stable API - so is likely to break ;)
>> A better approach is to (quickly, before 3.4 final!) file a PR
>> exposing the toggle atlas preview behavior to
>> QgsLayoutDesignerInterface. Then you'll be able to just do:
>> designer.toggleAtlasPreview( True )
>> Nyall
>> Hope anyone knows!
>>> Kind regards,
>>> Raymond
>>> QGIS-Developer mailing list
>>> QGIS-Developer at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
