[QGIS-Developer] open atlas layout, using python
Raymond Nijssen r.nijssen at terglobo.nl
Thu Oct 11 23:15:33 PDT 2018
Thank you Nyall, compiling now.
Yesterday I was asked to create a plugin that works on layouts, so it
will need a button in the layout composer. I think I could do this the
same fragile/hacky way, but is there a proper way?
I also find it hard to create reports from python, but maybe that is
still too young and not all finished?
Regards,
Raymond
On 12-10-18 01:39, Nyall Dawson wrote:
> On Fri, 12 Oct 2018 at 02:22, Raymond Nijssen <r.nijssen at terglobo.nl> wrote:
>> By the way, the fragile code solution does not work for me. It does
>> toggle the button but it does not activate the atlas preview.
> Ok - I've done the proper approach in
> https://github.com/qgis/QGIS/pull/8170/files
> (I've also exposed an API call to show the item properties for a
> particular item)
> Let me know if there's anything else you think should be exposed from
> the designer to the designer API.
> Nyall
>> # open layout
>> designer = iface.openLayoutDesigner(layout)
>> # turn on atlas preview mode
>> lo_view = designer.view()
>> lo_window = lo_view.window()
>> action = lo_window.findChild(QAction, 'mActionAtlasPreview')
>> action.toggle()
>> On 11-10-18 16:51, Raymond Nijssen wrote:
>>> Hi Nyall,
>>> It sounded great and I spent some hours on that better approach, but I
>>> didn't succeed. So maybe 3.6 will have it...
>>> Tnx!
>>> Raymond
>>> On 25-09-18 23:57, Nyall Dawson wrote:
>>>> On Tue, 25 Sep 2018 at 22:36, Raymond Nijssen <r.nijssen at terglobo.nl>
>>>> wrote:
>>>>> 1. Can I open a layout window with a python command?
>>>> designer = iface.openLayoutDesigner( layout )
>>>>> 2. Can I turn on "atlas preview" with a python command?
>>>> You'd have to do some fragile code to do this. Basically:
>>>> - get designer window from designer.view()'s parent window
>>>> - find the mActionAtlasPreview child action in the window
>>>> - manually toggle it on
>>>> This should work, but isn't stable API - so is likely to break ;)
>>>> A better approach is to (quickly, before 3.4 final!) file a PR
>>>> exposing the toggle atlas preview behavior to
>>>> QgsLayoutDesignerInterface. Then you'll be able to just do:
>>>> designer.toggleAtlasPreview( True )
>>>> Nyall
>>>> Hope anyone knows!
>>>>> Kind regards,
>>>>> Raymond
>>>>> _______________________________________________
>>>>> QGIS-Developer mailing list
>>>>> QGIS-Developer at lists.osgeo.org
>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
