[QGIS-Developer] Rotate or Offset Point symbol: how do they work? Or are they broken?
DelazJ delazj at gmail.com
Tue Oct 23 03:52:55 PDT 2018
Thanks, Nyall.
Le mar. 23 oct. 2018 à 03:06, Nyall Dawson <nyall.dawson at gmail.com> a
écrit :
> On Tue, 23 Oct 2018 at 03:17, DelazJ <delazj at gmail.com> wrote:
> > Hi,
> > Any clue on how the "Rotate Point symbol" or "Offset Point symbol"
> digitizing tools are expected to work? The docs [0] seems wrong (or
> broken?) and whatever I try (including creating a field named "rotation"),
> I get a "The selected point does not have a rotation (or an offset)
> attribute set." message. And no help on how I could set this attribute...
Works fine here. I just data define link it over to an appropriate
> field (numeric for rotation, string for offset), and then the tools
> work as described.
> Exactly what I did for the rotate tool. The And doing it again changes
nothing:
- I thought it had to do with temporary layer, hence switched to shp : fail
- swithed field type from integer to double: nothing
- I thought it was because i had not saved the file yet (something that
would be related to auxiliary storage) then I saved the file: niente
- May be it's a matter of qgs vs qgz? Neither
I always get that odd message about attribute not set.
I'm on Win 10 using master c94eefb6df. What could trigger that?
Harrissou
The only thing I can think of is that the docs are a little unclear here:
> "near the Rotation option of the highest level (preferably) of the
> symbol layers"
> This should be set at the "marker" level, not at an individual layer
> level. (i.e. click the "Marker" entry in the list, not "simple marker"
> and set the rotation there).
> Offset can be set at any layer and it will work.
> Nyall
> > [0]
> https://docs.qgis.org/testing/en/docs/user_manual/working_with_vector/editing_geometry_attributes.html#rotate-point-symbols
> > Regards,
> > Harrissou
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20181023/359673d1/attachment.html>
More information about the QGIS-Developer mailing list
