[QGIS-Developer] MAC QGIS 3.x build
Peter Petrik peter.petrik at lutraconsulting.co.uk
Thu Sep 13 01:05:16 PDT 2018
thank you for your suggestions and pointing me the to right places in
documentations.  After some struggle and frustration, I managed to setup my
MacOS environment to be able to do some productive work on QGIS. I ended up
with homebrew approach and especially
qgis/homebrew-qgisdev/development/README.md was helpful. The QGIS build
with qt 5.11.1 looks usable too.
Unfortunately I had some issues with tap qgis/homebrew-qgisdev. It is not
possible to even tap it from master and qgis3 formulae is not working. The
QGIS3 formulae in OSGeo4mac homebrew repository is updated and working. I
am wondering if qgis/homebrew-qgisdev is actively maintained and used?
Also, what is the benefit to maintain this formula over osgeo4mac/qgis3
formulae (they are very similar)?
Prepared https://github.com/qgis/homebrew-qgisdev/pull/72 with changes I
made to be able to build QGIS3 (I used the scripts, development/README.md
and followed the QT Creator path in the document). We should update
qgis/QGIS/INSTALL for OSX (that was the first doc I checked). I am happy to
help with docs and homebrew-qgisdev, but first I need to clarify the status
of qgis/homebrew-qgisdev.
Thanks,
Peter
On Tue, Sep 4, 2018 at 3:40 PM David Marteau <dmarteau at 3liz.com> wrote:
> Le 4 sept. 2018 à 15:12, William Kyngesburye <woklist at kyngchaos.com> a
> écrit :
> On Sep 4, 2018, at 4:24 AM, Nyall Dawson <nyall.dawson at gmail.com> wrote:
> On Tue, 4 Sep 2018 at 19:19, David Marteau <dmarteau at 3liz.com> wrote:
> Hi Peter,
> Warning, if you are using macport: qt5.11 is installed by default and you
> may (or may not)  experience some display problems, instead you may choose
> to stick to qt5.9 by installing
> the 'qt59' port
> Is that the infamous "small canvas" issue?
> I don't know about that, I use Qt 5.9 in my official build, and it has the
> small canvas problem.
> It is more about the "slowness" problem on Mac:
> https://trac.macports.org/ticket/56915  ,
> https://issues.qgis.org/issues/19546
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> "We are at war with them. Neither in hatred nor revenge and with no
> particular pleasure I shall kill every ___ I can until the war is over.
> That is my duty."
> "Don't you even hate 'em?"
> "What good would it do if I did? If all the many millions of people of the
> allied nations devoted an entire year exclusively to hating the ____ it
> wouldn't kill one ___ nor shorten the war one day."
> <Ha, ha> "And it might give 'em all stomach ulcers."
> - Tarzan, on war
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180913/8cad2098/attachment.html>
More information about the QGIS-Developer mailing list
