[QGIS-Developer] Build failure on macOS
Jürgen E. Fischer jef at norbit.de
Sun Sep 16 14:28:07 PDT 2018
Hi Tim,
On Sun, 16. Sep 2018 at 22:40:09 +0200, Tim Sutton wrote:
> resources/function_help/json/to_dm
> Traceback (most recent call last):
> File "/Users/timlinux/dev/cpp/QGIS/scripts/process_function_template.py", line 47, in <module>
> json_params = json.load(function_file)
Apprently an issue with the UTF-8 characters in the new expression help files -
I also see that in the nightlies of master on Linux - but not on local builds.
Jürgen
Jürgen E. Fischer           norBIT GmbH             Tel. +49-4931-918175-31
Dipl.-Inf. (FH)             Rheinstraße 13          Fax. +49-4931-918175-50
Software Engineer           D-26506 Norden             http://www.norbit.de
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180916/a8b463c6/attachment.sig>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180916/a8b463c6/attachment.ksh>
More information about the QGIS-Developer mailing list
