[QGIS-Developer] QGIS Server QGIS_PROJECT_FILE ignoring MAP parameter?
Stéphane Brunner stephane.brunner at camptocamp.com
Thu Sep 20 05:26:08 PDT 2018
Hello,
2018-09-20 14:22 GMT+02:00 Adam Borczyk <adam.borczyk at gis-support.pl>:
> Forgot my config if it matters:
> - Ubuntu server 18.04
> - QGIS Server 2.18
> - Apache 2.4.29 (config: https://pastebin.com/QnTc19Gj )
> On Thu, 20 Sep 2018 at 14:19, Adam Borczyk <adam.borczyk at gis-support.pl>
> wrote:
>> Hi everyone,
>> is it expected behaviour for QGIS Server 2.18 to ignore MAP parameter in
>> URL when QGIS_PROJECT_FILE environment variable is set?
Yes, because I want to publish only one project, we don't want that a user
can build a request to access to an other project...
Sincerely
Stéphane
>> I have QGIS_PROJECT_FILE set, so my endpoint "/wms" serves default
>> project, but I'd like to access another project from the same endpoint -
>> I'm trying here with just specifying MAP parameter, but changing it's value
>> does not affect response in any way. In fact, I can do "&MAP=asdfasdf" and
>> still get default project, while changing other parameters works normally.
>> I though Environment Variable works as default option that you can
>> override, but it seems it doesn't?
>> Best regards
>> Adam Borczyk
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
*Stéphane Brunner*
Geospatial Solutions
Software Developer
*camptocamp*
INNOVATIVE SOLUTIONS
BY OPEN SOURCE EXPERTS
camptocamp.com
mapfish.org
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180920/1f8e08f2/attachment-0001.html>
More information about the QGIS-Developer mailing list
