[QGIS-Developer] Advice? Sneaky trick for call out labels
Tim Sutton tim at kartoza.com
Wed Apr 10 23:43:40 PDT 2019
Hi Alexis, Régis and Nyall
I went with Nyall’s approach for now since I was 90% there and he gave me the last nudge I needed :-) I used data defined alignments:
Here are the expressions I used for horizontal:
if (
  X(closest_point($geometry,
  make_point( "auxiliary_storage_labeling_positionx" , "auxiliary_storage_labeling_positiony" ))) >
  X(make_point( "auxiliary_storage_labeling_positionx" , "auxiliary_storage_labeling_positiony" )),
  'Right', 'Left’)
Which gives (animated gif, open in browser if needed):
And Vertical
if (
  Y(closest_point($geometry,
  make_point( "auxiliary_storage_labeling_positionx" , "auxiliary_storage_labeling_positiony" ))) <
  Y(make_point( "auxiliary_storage_labeling_positionx" , "auxiliary_storage_labeling_positiony" )),
  ’Top’, ‘Bottom’)
@Régis I will give your plugin a try to see what it does too, thanks!
QGIS Rocks!
Regards
Tim
> On 11 Apr 2019, at 07:19, Régis Haubourg <regis.haubourg at gmail.com> wrote:
> Hi Tim,
> You can have a look at easycustomlabeling plugin code. It's sets those expressions for label alignement.
> FYI I should be working on a new version of it taking profit of the geometry generators power soon , and we might be able to revive the QEP47 to revive the idea of porting this natively to core.
> Best regards
> Regis
> Le jeu. 11 avr. 2019 à 00:54, Tim Sutton <tim at kartoza.com> a écrit :
> To clarify a little, I am trying to avoid the label text crossing the call-out line.
> Regards
> Tim
>> On 10 Apr 2019, at 23:02, Tim Sutton <tim at kartoza.com> wrote:
>> Hi Friends
>> So I am using logic like this* to make call out labels using a geometry generator:
>> make_line(
>> The line runs from the closest point along the edge of the polygon to the bottom left corner of the label box. With this configuration it works well when my ‘lollipop’ callout label is north-east of the polygon being labelled:
>> <Screenshot 2019-04-10 at 22.54.29.jpg>
>> But doesn’t work when the label is e.g. south west of the polygon:
>> <Screenshot 2019-04-10 at 22.54.54.jpg>
>> Now I am wondering if we have any options for getting the geometry of the label box so I can do the reverse and get the closest point along the edge of the label box to the polygon being labelled. So my question:
>> Is there any sneaky trick for getting the geometry of the label box for a feature in an expression? And no, using an opaque background for my label to mask away the call out line doesn’t really hack it. I know the label box isn’t being calculated at the time the polygon is being rendered so the answer is probably ’no’ but maybe someone else has a clever idea to make may lollipops work when labels are south (or east or west for that matter) of the feature being labelled?
>> Thanks!
>> Regards
>> Tim
>> <KartozaNewLogoThumbnail.jpg>
>> Tim Sutton
>> Co-founder: Kartoza
>> Ex Project chair: QGIS.org
>> Visit http://kartoza.com to find out about open source:
>> Desktop GIS programming services
>> Geospatial web development
>> GIS Training
>> Consulting Services
>> Skype: timlinux
>> IRC: timlinux on #qgis at freenode.net
>> I'd love to connect. Here's my calendar link to make finding time easy.
> Tim Sutton
> Co-founder: Kartoza
> GIS Training
> Consulting Services
> Skype: timlinux
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Tim Sutton
Co-founder: Kartoza
Visit http://kartoza.com <http://kartoza.com/> to find out about open source:
GIS Training
Consulting Services
Skype: timlinux
I'd love to connect. Here's my calendar link <https://calendly.com/timlinux> to make finding time easy.
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190411/89ea41d0/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190411/89ea41d0/attachment-0002.jpg>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190411/89ea41d0/attachment-0002.gif>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190411/89ea41d0/attachment-0003.gif>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190411/89ea41d0/attachment-0003.jpg>
More information about the QGIS-Developer mailing list
