[QGIS-Developer] Crashes on closing QGIS
Thomas Baumann rdbath.regiodata at gmail.com
Thu Apr 11 05:28:01 PDT 2019
Hi Nathan,
is this a configuration issue? Can I do something to get the correct
symbols in the stacktrace?
regards,
Thomas
Am Do., 11. Apr. 2019 um 12:52 Uhr schrieb Nathan Woodrow <
madmanwoo at gmail.com>:
> Nyall has hopefully fixed that bug already.  The one with proj_lpz_dist in
> the stack trace.  That isn't the real crash as that stack trace has no
> symbols so it's giving you the wrong info.  I got a stack trace the other
> day with correct symbols loaded and hopefully, it will be fixed now.
> - Nathan
> On Thu, Apr 11, 2019 at 5:06 PM Jürgen E. Fischer <jef at norbit.de> wrote:
>> Hi Thomas,
>> On Wed, 10. Apr 2019 at 23:04:50 +0200, Thomas Baumann wrote:
>> > proj_lpz_dist :
>> > QgsCoordinateTransform::transformPolygon :
>> > Does someone know what "proj_lpz_dist" stands for?
>> It's a function from PROJ:
>> https://proj4.org/development/reference/functions.html?highlight=deg#c.proj_lpz_dist
>> Jürgen
>> Jürgen E. Fischer           norBIT GmbH             Tel.
>> +49-4931-918175-31
>> Dipl.-Inf. (FH)             Rheinstraße 13          Fax.
>> +49-4931-918175-50
>> Software Engineer           D-26506 Norden
>> https://www.norbit.de
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190411/dc5fe7ab/attachment.html>
More information about the QGIS-Developer mailing list
