[QGIS-Developer] Globally setting FI_POINT_TOLERANCE on QGIS server
René-Luc Dhont rldhont at gmail.com
Tue Apr 16 07:01:45 PDT 2019
Hi Andreas,
We have build a plugin for doing so.
It is available for QGIS 2 and we are working on proting it to QGIS 3.
https://github.com/3liz/qgis-wmsGetFeatureInfoPrecision
Regards,
René-Luc
Le 16/04/2019 à 15:53, Alessandro Pasotti a écrit :
> On Tue, Apr 16, 2019 at 3:46 PM Andreas Neumann <a.neumann at carto.net
> <mailto:a.neumann at carto.net>> wrote:
>     Hi,
>     I wonder if it is possible to globally set/influence
>     the FI_POINT_TOLERANCE in QGIS server?
>     We'd like to configure QGIS server such, that by default it is a
>     bit more tolerant (using a larger search radius) for point features.
>     I know that the client can set the FI_POINT_TOLERANCE on
>     GetFeatureInfo request, but what if the client doesn't know about
>     QGIS and these special parameters?
>     Could this be set globally in QGIS server by an environment variable?
> No, that's not possible.
>     Thanks for your reply and greetings,
>     Andreas
>     _______________________________________________
>     QGIS-Developer mailing list
>     QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
>     List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Alessandro Pasotti
> w3: www.itopen.it <http://www.itopen.it>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190416/5a9a3230/attachment-0001.html>
More information about the QGIS-Developer mailing list
