[QGIS-Developer] Bug in QgsPathResolver ?
Nyall Dawson nyall.dawson at gmail.com
Tue Apr 23 14:35:42 PDT 2019
On Fri, 19 Apr 2019 at 23:24, David Marteau <dmarteau at 3liz.com> wrote:
> Hi devs,
> I have  a strange behavior with QgsPathResolver that prevent layer to be loaded if a QgsProject read config file from relative path:
> The problem has been reduced to the following behavior (pyQgis):
> # Init a QgsPathResolver as with a relative path
> pr = QgsPathResolver('./geography/data/france_parts.qgs')
Isn't this an odd/dangerous/fragile situation to begin with? I'd be in
favour of requiring QgsPathResolver to accept only absolute paths in
the constructor.
Nyall
> pr.readPath('./france_parts/france_parts.shp')
> # Output -> '/geography/data/france_parts/france_parts.shp'
> # Note the leading '/'
> Worst:
> pr = QgsPathResolver('../geography/data/france_parts.qgs')
> # Output -> '/../geography/data/france_parts/france_parts.shp'
> # which is a meaningless path
> The side effect is that if you do:
> prj = QgsProject()
> prj.read("./geography/data/france_parts.qgs")
> then you get the error:
> Qgis OGR: Cannot open /geography/data/france_parts/france_parts.shp.()
> Qgis : 1 unavailable layers found:
> Qgis :  * ./france_parts/france_parts.shp
> This is with Qgis 3.6.1
> Can anybody confirm that this behavior is a bug ? I will submit a PR  if this is the case.
> Thanks,
> Cheers
> David
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
