[QGIS-Developer] Event woes in QGIS
    Bo Victor Thomsen
    bo.victor.thomsen at gmail.com
    Thu Aug 22 03:46:37 PDT 2019
Hi Lars -
I hazard a guess, that you want to execute some action after a /project/
has finished loading.
You might have a look on how to execute macro's after open, save or
close events for the project:
In the project properties, you can enable macro's and write some python
code that will be stored in the project:
Example: (Open an attribute window with data from layer 'kommune" after
the project has finished loading)
|#--- macro start --- from qgis.core import QgsProject from qgis.utils
import iface def openProject(): layers =
QgsProject.instance().mapLayersByName('kommune') layer = layers[0]
iface.showAttributeTable(layer) def saveProject(): pass def
closeProject(): pass||#--- macro end ---|
Den 21-08-2019 kl. 14:15 skrev Lars I. Nielsen, LIFA A/S:
> Hi bold developers of QGIS.
> I’ve recently begun digging into utilizing the event (signal) model of
> QGIS (3.4).
> And I’ve encountered a number of frustrations, as the events don’t
> work the way they’re supposed to, at least according to the available
> documentation (https://qgis.org/pyqgis/master/core/index.html).
> E.g., the event “layerLoaded” on the project instance with the
> description “/Emitted when a layer from a projects (sic) was read/”,
> which to me indicates, that the loading is done (due to the use of
> “loaded” and “was”).
> But the event is emitted before the loading of the layer is done, and
> you are therefore unable to find the layer it concerns.
> Another example is the event “metadataChanged” on a loaded layer,
> which again to me indicates a past/done action (due to the use of
> “changed”). But again, it’s emitted before the change actually takes
> place, and the changed metadata isn’t available.
> If the two events are indeed preload events, their names should
> instead be something like “layerLoading” and “metadataChanging”, or
> even “layerPreLoad” and “metadataPreChange”.
> Is there a guide somewhere to tell how the event system is envisioned,
> and which events are emitted pre-action and which are emitted
> post-action ?
> Or must I (hopefully not) take a deep look into the QGIS source code
> itself for this kind of information ?
> In general, pre-action events are of limited use, except when it comes
> to deletions and destructions. For loading and changing stuff,
> post-action events are almost always what you need.
> Med venlig hilsen
> GIS-konsulent, FME Certified Professional
> Geoinformatik
> Beskrivelse:
> C:\Users\lin\AppData\Roaming\Microsoft\signatures\284x82-3741133837051347070
> *T*
> 6313 6800
> lin at lifa.dk
> *D*
> 6313 6849
> *W*
> www.lifa.dk <http://www.lifa.dk>
> *M*
> 2492 4866
> *CVR*
> 20937289
> Beskrivelse:
> C:\Users\lin\AppData\Roaming\Microsoft\signatures\21x21-3019966288736195652
> <https://www.linkedin.com/company/lifa-a-s/>
> Følg os på LinkedIn og læs de seneste nyheder fra LIFA A/S
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Med venlig hilsen / Kind regards
Bo Victor Thomsen
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190822/eed25f25/attachment-0001.html>
Type: image/gif
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190822/eed25f25/attachment-0001.gif>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190822/eed25f25/attachment-0001.png>
