[QGIS-Developer] QGIS & PROJ 6 & SAGA
Sebastiaan Couwenberg sebastic at xs4all.nl
Sun Dec 1 20:37:53 PST 2019
On 12/1/19 8:50 PM, William Kyngesburye wrote:
> I want to have PROJ 6 (and GDAL 3) for QGIS (should be fully supported in QGIS 3.10.1), but found a problem with SAGA.  QGIS is still using SAGA 2.3 (LTS) for API stability.  SAGA 2.3 is stuck on PROJ.4.  It's only the latest SAGA, v7.4 that finally updated for PROJ 6 support.
SAGA 7.3.0 is the new LTS, and supports PROJ 6.
You should upgrade to that.
Also note: https://plugins.qgis.org/plugins/processing_saga_nextgen/
Kind Regards,
Bas
 GPG Key ID: 4096R/6750F10AE88D4AF1
Fingerprint: 8182 DE41 7056 408D 6146  50D1 6750 F10A E88D 4AF1
More information about the QGIS-Developer mailing list
