[QGIS-Developer] [Qgis-psc] 2019 Grant Final reports: Rendering optimisation and labeling work
Nyall Dawson nyall.dawson at gmail.com
Tue Dec 3 16:06:20 PST 2019
On Tue, 3 Dec 2019 at 22:27, Régis Haubourg <regis.haubourg at gmail.com> wrote:
> Hi,
> Nyall, this is awesome work! Thanks a lot for this.
> I checked the daily performance tests for QGIS server available at http://test.qgis.org/perf_test/graffiti/aggregate/aggregate.html and couldn't see clear influence.
> Do you have ideas of tests we could add to this framework?
If you're checking nightly releases, you'd need to track back a couple
of months to before the work began in order to compare (since the
changes have been drip fed in over a couple of months).
Or alternatively you could compare against a 3.6 build (since many of
the optimisations were backported to 3.4 and 3.8/3.10).
Nyall
> Cheers
> Régis
> Le mar. 3 déc. 2019 à 08:43, Anita Graser <anitagraser at gmx.at> a écrit :
>> Thank you for the detailed report and the excellent work, Nyall!
>> I'm looking forward to testing it by upgrading some projects to the new labeling.
>> Anita
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
