[QGIS-Developer] Problems in running OTB
Pedro Venâncio
pedrongvenancio at gmail.com
Wed Dec 4 08:05:53 PST 2019
Hi Paolo,
Tested here in Ubuntu Xenial, both with OTB 7.0.0 or 6.6.1, and QGIS 3.4.13
(OTB plugin), everything works, but with the issues reported by Aron.
Best regards,
Pedro
Paolo Cavallini <cavallini at faunalia.it> escreveu no dia quarta, 4/12/2019
à(s) 15:44:
> Thanks for the feedback. Could you please add your notes to the ticket
> https://gitlab.orfeo-toolbox.org/orfeotoolbox/otb/issues/2001 ?
> Cheers.
> Il 04/12/19 14:42, Áron Gergely ha scritto:
> > Hi Paolo and list,
> > I am using the Segmentation algorithm on Linux without major problems.
> > (OTB 6.6 and now 7.0 with QGIS 3.10). But indeed it does not work out
> > of the box:
> > Even when raster output does not not apply to the Segmentation alg , a
> > "bogus" value would have to be entered in the output box to avoid an
> > exception and get the alg running.
> > Also, the OTB processing provider settings interface has some issues:
> > when I try to change configuration values (namely the amount of max RAM
> > ), I get an error " argument has unexpected type 'int' "
> > Best regards,
> > Aron
> > On 04/12/2019 13:23, Pedro Venâncio wrote:
> >> Hi Paolo,
> >> I'm using OTB (6.6.1 and 7.0.0) with QGIS 3.10.0, without any problem,
> >> but I'm on Windows.
> >> About the issues you reported (".raster.out.tif" and vectors not being
> >> loaded), I think this thread can explain almost all of them (I had the
> >> same doubts some time ago):
> >> https://gitlab.orfeo-toolbox.org/orfeotoolbox/qgis-otb-plugin/issues/30
> >> Best regards,
> >> Pedro Venâncio
> >> Paolo Cavallini <cavallini at faunalia.it <mailto:cavallini at faunalia.it>>
> >> escreveu no dia terça, 3/12/2019 à(s) 12:00:
> >> Moreover, the vector resulting vector layer is not automatically
> >> loaded.
> >> Cheers.
> >> Il 03/12/19 12:44, Paolo Cavallini ha scritto:
> >> > Hi all,
> >> > OTB algs apparently do not work on QGIS 3.10 out of the box:
> >> > * if a raster output is not explicitly selected I get an error:
> >> > “.raster.out.tif” files are not supported as outputs for this
> >> algorithm
> >> > * if a vector output is not explicitly selected (with
> >> filename.ext) I
> >> > get another error:
> >> > 2019-12-03 12:30:43 (FATAL) Segmentation: itk::ERROR: No OGR
> driver
> >> > known to OTB to create and handle a DataSource named
> </tmp/processing_1845b856b9b44fa79bd7d1f2f834ffa0/processing_5bc31a5446744fff806de1d05d4b0240/4083978a97c840adbe135f8409847bfd/mode.vector.out.file>.
> >> > If confirmed I can open two tickets.
> >> > Additionally (but this must be done by OTB itself, nothing to do
> >> with QGIS):
> >> > ERROR 1: TopologyException: Input geom 1 is invalid: Ring
> >> > Self-intersection at or near point 1651438.0098749998
> >> 4818821.1863940004
> >> > at 1651438.0098749998 4818821.1863940004
> >> > Cheers.
> >> Paolo Cavallini - www.faunalia.eu <http://www.faunalia.eu>
> >> QGIS.ORG <http://QGIS.ORG> Chair:
> >> http://planet.qgis.org/planet/user/28/tag/qgis%20board/
> >> _______________________________________________
> >> QGIS-Developer mailing list
> >> QGIS-Developer at lists.osgeo.org <mailto:
> QGIS-Developer at lists.osgeo.org>
> >> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> >> Unsubscribe:
> >> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Email Signature Kind Regards,
> > Áron Gergely
> > +31 (0) 6 38 70 97 66
> > *Rasterra* | www.rasterra.nl <https://www.rasterra.nl>
> QGIS.ORG Chair:
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20191204/7c5cf120/attachment.html>
