[QGIS-Developer] osgeo4w's qgis-dev package broken, proj_7_0.dll missing
Régis Haubourg
regis.haubourg at gmail.com
Fri Dec 6 05:00:46 PST 2019
great news.
Does that mean QGIS 3.4 LTR will continue its life as expected? Or is
3.4.14 the last one?
thanks for your lights, we need to communicate quickly if LTR is frozen
now.
Regards
Régis
Le ven. 6 déc. 2019 à 00:06, Nyall Dawson <nyall.dawson at gmail.com> a écrit :
> On Fri, 6 Dec 2019 at 07:54, Jürgen E. Fischer <jef at norbit.de> wrote:
> > Hi,
> > On Thu, 05. Dec 2019 at 11:22:35 +0000, Pedro Venâncio wrote:
> > > But I believe that should be fixed in the next build.
> > Yes, the rebuild has picked the new proj up.
> > Rhere also a new qgis-ltr now - and new standalones for 3.4.13.
> > As that also required updates to the build scripts in the release branch
> > tomorrows 3.4.14 should be almost the same - except for some
> translations…
> Testing 3.4.13, it looks like you've successfully found a solution to
> use gdal < 3 and proj < 6 for the 3.4 build?
> Great work!!
> Nyall
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20191206/d5ff714c/attachment.html>
