[QGIS-Developer] Improve build times with ccache
Matthias Kuhn matthias at opengis.ch
Mon Dec 16 00:02:22 PST 2019
Ccache is certainly a good idea.
The other one is to actually keep several source and build folders in
parallel (e.g. release-3_4, release-3_10, master). I would recommend
getting familiar with "git worktree" which is an amazing utility to use
several sources in parallel, based on the same git configuration.
I quite often develop small fixes on a master tree with mixed patches on
top and then compile this mixed branch and do:
git commit
git worktree add ../my_new_functionality
cd ../my_new_functionality
git rebase -i qgis/master
# only keep the commits to be pushed
git push -u my_own_repo my_new_functionality
For small fixes here and there this is super fast to work with
Hope this helps
Matthias
On 12/16/19 8:57 AM, Samweli wrote:
> Hi, I just joined Kartoza and I am going to be doing a bunch of work on the
> QGIS core. Can someone share a good practice to avoid lengthy recompilation
> times when I switch branches. I'm using ccache in compiling.
> Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-f4099106.html
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
