[QGIS-Developer] What to do about GDAL and PROJ for 3.10.2?
Paolo Cavallini
cavallini at faunalia.it
Wed Dec 18 22:52:03 PST 2019
Hi Nyall,
thanks for clarifying this. Wouldn't it be reasonable to ask gdal+proj
teams to release a new fixed version ASAP? Even if we fix this in the
Windows installer, where we (Juergen) have full control, we'll still
have issues on other OSs where we cannot control dependencies.
Cheers.
Il 19/12/19 03:37, Mathieu Pellerin ha scritto:
> Having helped out chasing down some of these CRS and transformation
> issues under GDAL3/PROJ6, I too feel *very* uncomfortable shipping the
> next QGIS point release with anything lesser than GDAL3 and PROJ6 master
> as of yesterday.
> To be clear, QGIS had plenty to fix itself, and that’s been taken care
> of (thanks to QGIS’s PSC for financing Nyall here). But those fixes are
> half of the story, and if we are to ship a QGIS version built against
> GDAL3/PROJ6 that can be trusted to project and transform data properly,
> we can’t do so unless we ship with the latest revisions of those libraries.
> On the short term, since the next point release is in 24-ish hours, I’d
> suggest to update the osgeo4w gdal and proj non-dev libraries to the
> latest master revisions (with versions like proj6 version 6.3pre or
> something) and have QGIS 3.10.2 built against those. Jürgen, since you’d
> carry that library update burden, how do you feel about this solution?
> Following that, we should discuss with GDAL and PROJ to see if they can
> package an official release prior to QGIS’ next point release (which is
> to take place on January 17, 2019 according to our schedule). Once
> that’s done, we should consider raising QGIS’ minimum version
> requirement for those libraries.
> Math
> On Thu, Dec 19, 2019 at 8:30 AM Nyall Dawson <nyall.dawson at gmail.com
> <mailto:nyall.dawson at gmail.com>> wrote:
> Hi list,
> Just want to raise this discussion prior to the 3.10.2 patch release.
> The situation as I see it is that there is absolutely critical fixes
> in GDAL and PROJ master branches which are not available in any of the
> GDAL/PROJ stable releases, all relating to CRS and transformation
> handling.
> Many of these fixes have been implemented as a direct result of bug
> reports filed against QGIS when running under the Proj6/GDAL3
> combination.
> I personally do not feel comfortable with anyone running QGIS on
> GDAL3/Proj6 without these fixes (in fact, I think that we should block
> QGIS builds on GDAL/PROJ builds less than master, and greater than
> PROJ 5/ GDAL 2 via cmake checks). So we're left in a difficult
> position, because the next round of GDAL/PROJ releases aren't
> happening anytime soon.
> Thoughts welcome on how we should proceed here....
> Nyall
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Paolo Cavallini - www.faunalia.eu
QGIS.ORG Chair:
http://planet.qgis.org/planet/user/28/tag/qgis%20board/
