[QGIS-Developer] Jupyter Console Plugin for QGIS?
Stefan Keller sfkeller at gmail.com
Sun Feb 3 03:20:00 PST 2019
Am So., 3. Feb. 2019 um 11:00 Uhr schrieb Luigi Pirelli <luipir at gmail.com>:
> I hadn't time to investigate, but 1.5y ago I challenged various talented devs and none found a solution...
> But having a well focused GSoC probably could help :)
So ;-) , do we have a good idea for GSoC 2019 - and a mentor (you)?
My contribution could be use and test cases...
:Stefan
> There were already a past GSoC focused on something similar... But oriented to use qgis as back end for mapping only.
> IMHO a GSoC should be on remove (if possible) at console ernel sharing limitation when embedded.. Not specifically a qgis oriented stuff.
> I hadn't time to investigate, but 1.5y ago I challenged various talented devs and none found a solution... But having a well focused GSoC probably could help :)
> On Sunday, 3 February 2019, Stefan Keller <sfkeller at gmail.com> wrote:
>> A Jupyter Console QGIS Plugin would probably be a good "Google Summer
>> of Code 2019 Idea"?
>> https://github.com/qgis/QGIS/wiki/Google-Summer-of-Code-2019-Ideas
>> :Stefan
>> Am Do., 31. Jan. 2019 um 23:07 Uhr schrieb Luigi Pirelli <luipir at gmail.com>:
>> > I already wrote many times about QT Console limitations to interact with external kernels... I dind't know about RichJupyterWidget and I'm not updated about qt console evlution.
>> > IMHO if it works would be great... since 1.5y ago it was not possible.
>> > Luigi Pirelli
>> > * LinkedIn: https://www.linkedin.com/in/luigipirelli
>> > * Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
>> > * GitHub: https://github.com/luipir
>> > * Mastering QGIS 2nd Edition:
>> > * https://www.packtpub.com/big-data-and-business-intelligence/mastering-qgis-second-edition
>> > * Hire me: http://goo.gl/BYRQKg
>> > On Thu, 31 Jan 2019 at 21:03, Alessandro Pasotti <apasotti at gmail.com> wrote:
>> >> Stefan,
>> >> this is actually a very good idea, I've started something similar a few years ago, but its scope was limited to embedding the IPython console inside QGIS, the plugin is available here: https://plugins.qgis.org/plugins/IPyConsole/
>> >> It is based on QtConsole.
>> >> Perhaps it could be a starting point, IIRC Luigi also explored this possibility while we were working together in Boundless.
>> >> On Thu, Jan 31, 2019 at 8:11 PM Stefan Keller <sfkeller at gmail.com> wrote:
>> >>> Hi,
>> >>> August 2017 Tim S. blogged about "Plotting the future of QGIS" [1] and
>> >>> mentioned as no. 1. "We need to beef up the analytical capabilities in
>> >>> QGIS". There he asked "why not provide both a Jupyter Notebook"
>> >>> embedded into QGIS and pointed to options to integrate the Jupyter Qt
>> >>> console [2]. QGIS/Jupyter integration has been mentioned 2017 as
>> >>> possible GSoC but then can't see other activities.
>> >>> So what is your opinion about writing a QGIS Python Plugin which
>> >>> allows to run Python notebooks an accesses the QGIS processing power
>> >>> (e.g. using Qt's  RichJupyterWidget).
>> >>> Any developments or thoughts on this?
>> >>> :Stefan
>> >>> [1] https://blog.qgis.org/2017/08/25/plotting-the-future-of-qgis/
>> >>> [2] https://qtconsole.readthedocs.io/en/stable/#embedding-the-qtconsole-in-a-qt-application
>> >>> _______________________________________________
>> >>> QGIS-Developer mailing list
>> >>> QGIS-Developer at lists.osgeo.org
>> >>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> >>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> >> Alessandro Pasotti
>> >> w3:   www.itopen.it
> Luigi Pirelli
More information about the QGIS-Developer mailing list
