[QGIS-Developer] Windows only version of a QGIS 2.18x plugin
Nyall Dawson nyall.dawson at gmail.com
Tue Feb 5 22:47:56 PST 2019
On Wed, 6 Feb 2019 at 16:29, <Christina.Ratcliff at csiro.au> wrote:
> On uploading to the QGIS repository I have been advised by @pcav (see https://github.com/CSIRO-Precision-Agriculture/PAT_QGIS_Plugin/issues/7 ) that PAT must support Linux and OSX operating environments. I have had a look on https://plugins.qgis.org/ and I cannot find where this is listed in bullet points under how to add your plugin to this repository as a requirement for the approval of plugins. @pcav advised that I email this list regarding this issue.
*snip*
Don't we have other tools in the repo which are dependant on
platform-specific binaries? E.g.  "Cuda Raster" is linux only.
Nyall
> Is it acceptable to add a line in the metadata.txt file clearly pointing out that this plugin is to be used in Windows only and will it still be approved for the QGIS plugin repository?
> If not what are my options?
> Are there any guides on how to best setup and test QGIS plugins for Linux and OSX environments? I only have access to Windows at the moment and I am a novice at Python programming in these other environments.
> Any help or direction would be greatly appreciated.
> Kind Regards,
> Christina Ratcliff
> PLEASE NOTE
> The information contained in this email may be confidential or privileged. Any unauthorised use or disclosure is prohibited. If you have received this email in error, please delete it immediately and notify the sender by return email. Thank you. To the extent permitted by law, CSIRO does not represent, warrant and/or guarantee that the integrity of this communication has been maintained or that the communication is free of errors, virus, interception or interference.
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
