[QGIS-Developer] Windows only version of a QGIS 2.18x plugin
Matthias Kuhn matthias at opengis.ch
Wed Feb 6 05:16:35 PST 2019
Hi Axel,
There is the possibility to run continuous integration on various
platforms on travis-ci and there are other continuous integration
services as well. But I don't think you have the possibility to manually
click through the user interface there and really need to setup unit /
integration tests.
Matthias
On 2/6/19 1:59 PM, Axel Andersson wrote:
> On the subject, is there any possibility to test a plugin at another
> platform?
> I'm developing my plugin on Windows machine and I have a Linux server,
> which I can test the plugin on but when it comes to OSX I have no
> machine to test it on. Does anyone have experience/good cookbooks how
> to set up a OSX virtual box or something similar to test a plugin in?
> Best regards
> Axel
> On Wed, 6 Feb 2019 at 13:05, Matthias Kuhn <matthias at opengis.ch
> <mailto:matthias at opengis.ch>> wrote:
>     Hi
>     On 2/6/19 12:47 PM, Nathan Woodrow wrote:
>     > QGIS is for the users in the end, if this opens a new world of
>     users,
>     > and note this is government funded, I don't think we should avoid
>     > allowing these kinds of things in.  This isn't a core feature of
>     QGIS
>     > and more of an exception than a rule.  I don't see most plugins
>     going
>     > this route but the few that do because of X reasons they have no
>     > control over should still be part of the community I think.
>     > I really don't see the harm here as it's not something that most
>     > people will know or care about in the end.  Getting plugins to work
>     > cross-platform is a lot of work and I don't really like pushing
>     people
>     > away because they can't do it for whatever reason.  If this was
>     going
>     > to be a core feature I would be on your side for it but the plugins
>     > are for the users.
>     > I would also note we have some features of QGIS that only work
>     on some
>     > platforms and not others and we are fine with that because it
>     makes it
>     > better for those users, so this is the same here IMO.  Pushing them
>     > out to a self-hosted plugin repo just adds extra overhead and limits
>     > user base and visibility of well-funded work that we should embrace.
>     I am tempted to think in the same direction. Most plugins will be
>     cross-platform anyway because Python and because Qt and because QGIS.
>     If they are not and it's trivial to solve (e.g. someone is using \ as
>     path separator instead of os.path.join...) than things can go
>     through an
>     issue report. If it's more complex it's a question of effort vs.
>     benefit. If it's a single-purpose use-case specific plugin which is
>     intended to be run inside a specific organization / scenario, then I
>     don't see the benefit of investing a lot of effort into something that
>     will never be used.
>     IMO we should be open to anyone and in parallel encourage people to
>     support as many platforms as possible. E.g. adding metadata with
>     supported platforms might help to be more transparent about supported
>     platform, filter plugins in the plugin manager and offer specific help
>     to make plugins cross-platform down the road.
>     Bests
>     Matthias
>     _______________________________________________
>     QGIS-Developer mailing list
>     QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
>     List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Matthias Kuhn
matthias at opengis.ch <mailto:matthias at opengis.ch>
+41 (0)76 435 67 63 <tel:+41764356763>
OPENGIS.ch Logo <http://www.opengis.ch>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190206/60836100/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190206/60836100/attachment.png>
More information about the QGIS-Developer mailing list
