[QGIS-Developer] Changes to @atlas_feature?
Spencer Gardner spencergardner at gmail.com
Mon Feb 11 15:58:59 PST 2019
I have a map document set up with a report that filters an attribute table
based on an attribute in the layers used for filtering (i.e. the "atlas"
layer for lack of a better Reports-oriented term). In 3.4.2 I could use
the @atlas_feature variable to grab the attribute I needed, but I've
discovered this doesn't work in 3.4.4. Was there a change to the handling
of @atlas_feature between the two versions? If so, I'll file a bug report.
Otherwise, I'm at a loss as to what's going on.
Thanks!
Spencer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190211/2c9381f9/attachment.html>
More information about the QGIS-Developer mailing list
