[QGIS-Developer] Plugins translation
Jorge Almerio jorgealmerio at yahoo.com.br
Wed Feb 13 04:51:42 PST 2019
Hi devs,
For do the plugin translations I use
1) Linguist from QT5
2) The command line:
    Pylupdate4 -noobsolete PluginName.pro (Is there a new version 5??)
3) and the classical code:
        # initialize locale
        locale = QSettings().value('locale/userLocale')[0:2]
        locale_path = os.path.join(
            self.plugin_dir,
            'i18n',
            'PluginName_{}.qm'.format(locale))
        if os.path.exists(locale_path):
            self.translator = QTranslator()
            self.translator.load(locale_path)
            if qVersion() > '4.3.3':
                QCoreApplication.installTranslator(self.translator)
        def tr(self, message):
            return QCoreApplication.translate(QWaterPlugin.SETTINGS, message)
The problem is that the option to use self.tr('message string') is not working. It only works when I use QCoreApplication.translate('Escope', 'message string') even if a tr function defined.
It used to work with linguist from QT4.
What  Am I doing wrong? BTW Is there a new better way to translate plugins?
Another thing, every time I update the translations strings with Pylupdate4, I have to translate all my plugin forms again even without any changes, any help???
Thanks,
Jorge Almerio
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190213/713593d3/attachment-0001.html>
More information about the QGIS-Developer mailing list
