[QGIS-Developer] Download the QGIS User Manual HTML Files
Matthias Kuhn matthias at opengis.ch
Tue Feb 19 00:33:37 PST 2019
Hi Alexandre,
What would be required to add an additional build step to zip the whole
content including everything after build and push that to a downloadable
location?
Matthias
On 18.02.19 18:55, Alexandre Neto wrote:
> Hi,
> Yes, once the documentation is built, all images are gathered in the
> same folder, which means that there is no way split each document in a
> clean way. To separate a certain document (e. g., the user manual) you
> need to ignore the other sections in the conf.py or directly on the
> sphinx_build command.
> On the other hand, adding other languages shouldn't increase the file
> size that much, because most images are shared (we don't have many
> localized screenshots).
> See you soon.
> Alexandre Neto
> A seg, 18/02/2019, 16:51, Matthias Kuhn <matthias at opengis.ch
> <mailto:matthias at opengis.ch>> escreveu:
>     Hi Richard
>     On 2/18/19 5:10 PM, Richard Duivenvoorde wrote:
>>     On 18/02/2019 16.24, Matthias Kuhn wrote:
>>>     Hi,
>>>     In the QGIS options, there is a list of alternative help paths to search
>>>     for documentation.
>>>     Is there a zip file (or other means) available to download these docs to
>>>     keep them locally? I failed to find something.
>>     Hi Matthias,
>>     Nope, nothing available. The idea is/was that we add an extra step in
>>     the build Makefile to just zip the language build and rsync it to the
>>     docs server, OR to another download server.
>>     One thing to note is that we (maybe Alexander Neto has better details)
>>     do not have separated builds/image directories for all the docs in the
>>     documentation tree (Documentation, PythonCookbook, Gentle Gis Intro, Doc
>>     Guidelines).
>>     I created a zip from this nights build for you:
>>     https://docs.qgis.org/testing/qgisdocs_en.zip   (183Mb)
>     Thanks a lot for that!
>>     I would be happy to split this up though.
>>     My idea was to let people choose to download one language (for the
>>     non-testing builds).
>>     I was hoping that we could leave it zipped on the file-system and be
>>     able to view in either in users browser OR in an embedded webkit widget
>>     or so.
>     How much data are we talking about, the 183Mb from the link above?
>     If it's not considerably more, I would say in order to minimize
>     the overhead we could just serve this monolithic file with all doc
>     parts/languages included in a first step and require the user to
>     unzip it himself.
>     Regards
>     Matthias
>>     Regards,
>>     Richard
>>     _______________________________________________
>>     QGIS-Developer mailing list
>>     QGIS-Developer at lists.osgeo.org  <mailto:QGIS-Developer at lists.osgeo.org>
>>     List info:https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>     Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-developer
>     Matthias Kuhn
>     matthias at opengis.ch <mailto:matthias at opengis.ch>
>     +41 (0)76 435 67 63 <tel:+41764356763>
>     OPENGIS.ch Logo <http://www.opengis.ch>
>     List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>     Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Alexandre Neto
> @AlexNetoGeo
> http://sigsemgrilhetas.wordpress.com
> http://gisunchained.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190219/028d027c/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190219/028d027c/attachment-0001.png>
More information about the QGIS-Developer mailing list
