[QGIS-Developer] Changes to @atlas_feature?
Spencer Gardner spencergardner at gmail.com
Wed Feb 27 13:17:29 PST 2019
I'm still seeing issues. From what I can tell, the Expression generator
appears to be correctly reading the @atlas_feature variable now, and in
fact most references in the Reports are working correctly. However, my
attribute tables are still empty on the Reports page. I'll file a bug
report to see if we can get to the bottom of it.
On Mon, Feb 11, 2019 at 8:47 PM Nyall Dawson <nyall.dawson at gmail.com> wrote:
> On Tue, 12 Feb 2019 at 09:59, Spencer Gardner <spencergardner at gmail.com>
> wrote:
> > I have a map document set up with a report that filters an attribute
> table based on an attribute in the layers used for filtering (i.e. the
> "atlas" layer for lack of a better Reports-oriented term). In 3.4.2 I could
> use the @atlas_feature variable to grab the attribute I needed, but I've
> discovered this doesn't work in 3.4.4. Was there a change to the handling
> of @atlas_feature between the two versions? If so, I'll file a bug report.
> Otherwise, I'm at a loss as to what's going on.
> That's an unfortunate bug in 3.4.4 - it's fixed for next weeks 3.4.5
> release.
> Nyall
> > Thanks!
> > Spencer
> > QGIS-Developer mailing list
> > QGIS-Developer at lists.osgeo.org
> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190227/df74b124/attachment.html>
More information about the QGIS-Developer mailing list
