[QGIS-Developer] QGIS 3.8 Transformations dialog
Nyall Dawson nyall.dawson at gmail.com
Sun Jul 7 17:13:13 PDT 2019
On Mon, 1 Jul 2019 at 11:11, Nyall Dawson <nyall.dawson at gmail.com> wrote:
> On Fri, 28 Jun 2019 at 17:29, Nyall Dawson <nyall.dawson at gmail.com> wrote:
> > On Fri, 28 Jun 2019 at 17:11, Richard Duivenvoorde <rdmailings at duif.net> wrote:
> > > On 28/06/2019 01.28, Nyall Dawson wrote:
> > > >> That one shows 'just' 2 options (added to the qgis.nl post)
> > > >> IF the green line is just the first one, but we are not sure if it is
> > > >> the right one... should we make it green anyway?
> > > > Ah, on proj 6 builds, we ARE sure that the first/green one is the most
> > > > recommended one :) That's because proj gives us an ordered list of
> > > > possible operations in order of preference (calculated using all
> > > > proj's internal smarts and knowledge about the accuracy of different
> > > > transform operations).
> > > Mmm, then my last question, after this I'll move to proj ;-)
> > > See:
> > > http://www.qgis.nl/media/2019/06/Screenshot-20190627104509-716x467.png
> > > This is QGIS with proj6: As you see there are 2 options. The first one
> > > being green 'numbered' (3). But the bottom one having a higher number
> > > between brackets having a (4) between brackets?
> > > Now /me wondering what these numbers are: because given your answer
> > > above, the green one being 'THE one' :-) I wonder what this other
> > > numbers are (I was wondering ordered by date/relevance or so)??
> > These are how proj identifies the coordinate operation -- I'm not
> > entirely sure what they represent, but I assume they are just indexes.
> Just for followers of this thread - conversation moved to the proj
> mailing list, and looks like it will result in improved descriptive
> strings coming as a result...
Following all this discussion, here's a quick comparison of before vs current:
Before: http://www.qgis.nl/media/2019/06/Screenshot-20190627104509-716x467.png
Now: https://user-images.githubusercontent.com/1829991/60775333-f4f4db80-a164-11e9-8076-225ba2322aba.png
Iterative design at its finest ;)
Nyall
More information about the QGIS-Developer mailing list
