[QGIS-Developer] QGIS 3.8.0 on FreeBSD: build takes several hours
lbartoletti lbartoletti at tuxfamily.org
Fri Jul 12 12:47:25 PDT 2019
Hi Matthias, Rainer,
Matthias, I tested but unfortunately I can't reproduce the problem with this
code. Tested with llvm 6, 7 and 8 on FreeBSD 12 and 13 amd64.
But, of course :), the problem is still present for QGIS with llvm 8.0.1 on
FreeBSD 13.
For information, I created a CI on Cirrus for FreeBSD 12 and here the
results: https://cirrus-ci.com/task/5576588232491008 and my fork of your
repository https://github.com/lbartoletti/qmap_initializer_compile_time
Thanks to take care about this issue.
Loïc
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-f4099106.html
More information about the QGIS-Developer mailing list
