[QGIS-Developer] DBManager save querys only saves selected code - Bug or Feature?
Etienne Trimaille
etienne.trimaille at gmail.com
Sun Jul 21 03:34:10 PDT 2019
There is already a ticket: https://github.com/qgis/QGIS/issues/30616
Le dim. 21 juil. 2019 à 11:11, Paolo Cavallini <cavallini at faunalia.it> a
écrit :
> Hi all.
> I agree, the default should be save all. Having the option of savings only
> selected could be handy.
> Cheers.
> On 21 July 2019 10:29:21 CEST, Matthias Kuhn <matthias at opengis.ch> wrote:
>> Hi,
>> Is there any other software with this behavior to "save only selected"?
>> Or a use case where this is desirable?
>> From top of my mind I can't find anything and I think all our other
>> editors always save the full text, regardless of selection.
>> Regards
>> Matthias
>> On 7/21/19 10:19 AM, Alexandre Neto wrote:
>> I agree that it can be a feature, but needs to be more explicit to the
>> user.
>> My problem is that I was creating several instructions and running them
>> one by one. Then, in the end, I wanted to save everything and didn't
>> realize that there was a selection.
>> Documentation alone won't be enough IMHO. So, maybe a check box with
>> "Save selected only?
>> Anyway, thanks for making saving available.
>> Alex
>> A Sáb, 20/07/2019, 18:27, Loïc Bartoletti <lbartoletti at tuxfamily.org>
>> escreveu:
>>> Hi Alexandre,
>>> It's my bad, I used _getSqlQuery
>>> <https://github.com/lbartoletti/QGIS/blob/master/python/plugins/db_manager/dlg_sql_window.py#L557>
>>> insted of self.editSql.text().
>>> For me a feature must be documented and for this one the user must have
>>> the choice between the full text or the selected part. So it's a bug or I
>>> add this option and the doc.
>>> Regards,
>>> Loïc
>>> Le 20/07/2019 à 17:04, Alexandre Neto a écrit :
>>> Hi,
>>> I had some frustrations with the DB Manager save query functionality. At
>>> some point I finally understood that, if there is some selected code, only
>>> that part is saved.
>>> To me it's weird, because when you save, the rest of the code is
>>> maintained in the SQL editor, and the name of the query is showned in the
>>> topo.
>>> But, when I turn of my project and open it again, surprise surprise,
>>> only the selected part is in the Query.
>>> Bug or feature?
>>> Alex Neto
>>> QGIS-Developer mailing listQGIS-Developer at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Sorry for being short
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190721/a22fde9e/attachment.html>
