[QGIS-Developer] DBManager save querys only saves selected code - Bug or Feature?
Alexandre Neto senhor.neto at gmail.com
Thu Jul 25 01:50:42 PDT 2019
This has been fixed already.
Thanks Loïc,
Alex
A Seg, 22/07/2019, 00:13, Nyall Dawson <nyall.dawson at gmail.com> escreveu:
> On Sun, 21 Jul 2019 at 18:29, Matthias Kuhn <matthias at opengis.ch> wrote:
> > Hi,
> > Is there any other software with this behavior to "save only selected"?
> Or a use case where this is desirable?
> > From top of my mind I can't find anything and I think all our other
> editors always save the full text, regardless of selection.
> +1 to that. If a user really needs to save only a selected portion I
> think it's fine to require them to copy that part to a text editor and
> save from there. I'd rather not overload the UI with two options "save
> all"/"save selected bit only", it's just overkill.
> Nyall
> > Regards
> > Matthias
> > On 7/21/19 10:19 AM, Alexandre Neto wrote:
> > I agree that it can be a feature, but needs to be more explicit to the
> user.
> > My problem is that I was creating several instructions and running them
> one by one. Then, in the end, I wanted to save everything and didn't
> realize that there was a selection.
> > Documentation alone won't be enough IMHO. So, maybe a check box with
> "Save selected only?
> > Anyway, thanks for making saving available.
> > Alex
> > A Sáb, 20/07/2019, 18:27, Loïc Bartoletti <lbartoletti at tuxfamily.org>
> escreveu:
> >> Hi Alexandre,
> >> It's my bad, I used _getSqlQuery insted of self.editSql.text().
> >> For me a feature must be documented and for this one the user must have
> the choice between the full text or the selected part. So it's a bug or I
> add this option and the doc.
> >> Regards,
> >> Loïc
> >> Le 20/07/2019 à 17:04, Alexandre Neto a écrit :
> >> Hi,
> >> I had some frustrations with the DB Manager save query functionality.
> At some point I finally understood that, if there is some selected code,
> only that part is saved.
> >> To me it's weird, because when you save, the rest of the code is
> maintained in the SQL editor, and the name of the query is showned in the
> topo.
> >> But, when I turn of my project and open it again, surprise surprise,
> only the selected part is in the Query.
> >> Bug or feature?
> >> Alex Neto
> >> _______________________________________________
> >> QGIS-Developer mailing list
> >> QGIS-Developer at lists.osgeo.org
> >> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> >> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190725/b20b6bce/attachment.html>
More information about the QGIS-Developer mailing list
