[QGIS-Developer] Catch Python exceptions in QGIS console
Jorge Gustavo Rocha jgr at di.uminho.pt
Thu Jun 13 16:41:47 PDT 2019
Hi Nyall,
This problem only happens in Windows. In Linux, everything is running fine.
I was convinced that it was a Python exception, but for some reason, it
was not caught.
I will investigate this issue further. It makes me crazy!
Thank you for the feedback,
Jorge
Às 00:05 de 14/06/19, Nyall Dawson escreveu:
> On Fri, 14 Jun 2019 at 00:11, Jorge Gustavo Pereira Bastos Rocha
> <jgr at di.uminho.pt> wrote:
>> Hi devs,
>> Am I able to catch Python exceptions in Python console?
> Yes, definitely
>> I'm trying to debug a DB Manager related issue [1] using pg_services. I have the following piece of code, that runs fine in my computer, but fails on any other computer, within a specific intranet.
>> import psycopg2
>> print (psycopg2.__version__)
>> try:
>>     connection = psycopg2.connect(service='pg_trabalho')
>>     cursor = connection.cursor()
>>     print ( connection.get_dsn_parameters(),"\n")
>>     cursor.execute("SELECT version();")
>>     record = cursor.fetchone()
>>     print("Connected to - ", record,"\n")
>> except:
>>     print( psycopg2.InterfaceError )
>>     print( psycopg2.OperationalError )
>> When I run it, QGIS crashes [2]. I would prefer to handle the exception myself. How can I catch the exception without crashing QGIS?
> This crash isn't caused by a Python exception -- it's something
> deeper. If it was just a Python exception you'd see exactly the same
> results as something like
>     a = [1]
>     print(a[2])
> Unfortunately, these kinds of crashes can be extremely difficult to
> diagnose (especially if they are only reproducible on Windows). If you
> can reproduce on Linux, I'd suggest running under valgrind and looking
> for clues.
> Nyall
J. Gustavo
Jorge Gustavo Rocha
Departamento de Informática
Universidade do Minho
4710-057 Braga
Tel: +351 253604480
Fax: +351 253604471
Móvel: +351 910333888
skype: nabocudnosor
More information about the QGIS-Developer mailing list
