[QGIS-Developer] KMZ Embedded Ground Overlays to QGIS
C Hamilton adenaculture at gmail.com
Fri Jun 21 07:50:46 PDT 2019
I am thinking about adding support for KML ground overlays in my KML Tools
plugin. The ground overlay specifies the latitude and longitude of each of
the 4 corners of the image being overlaid. I think that in order to make
this work I would need to extract the images from the KMZ file and come up
with the proper transformation to use with GDAL and create a GeoTIFF of
each file. The GeoTIFFs could then be loaded into QGIS
Do you have any suggestions on how to specify the transformation for GDAL?
Thanks,
Calvin
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190621/e55cd74c/attachment.html>
More information about the QGIS-Developer mailing list
