[QGIS-Developer] MacOS and touchbar
Nyall Dawson nyall.dawson at gmail.com
Sun Mar 3 15:31:28 PST 2019
On Sat, 23 Feb 2019 at 07:34, Nyall Dawson <nyall.dawson at gmail.com> wrote:
> Hi list,
> This is just a heads up for any MacOS developers -- there's been some
> upstream work recently on Qt and handling the MacOS touchbar. There's
> two separate pieces of work here:
> 1. A (proposed) upstream Qt class - QMacTouchBar. Read more here:
> https://www.kdab.com/qmactouchbar-has-landed/
> Looks good in that it's intended to be part of the Qt library.
FWIW - this PR was shut down and won't be included in Qt. Basically
the maintainers do not see the point of supporting single-platform
features like this in Qt.
If anyone is still interested in implementing this in QGIS, there's
also https://github.com/msorvig/qt-touchbar for inspiration.
Nyall
> 2. QtCreator's own implementation of touchbar handling - see
> https://code.qt.io/cgit/qt-creator/qt-creator.git/commit/?id=3c5650e514d6d8bad86a54a037e550db7cc19a71
> This one actually looks a lot nicer then QMacTouchBar, because it
> allows for "nested" touchbars based on QAction.
> If any MacOS developers* are motivated, I'd suggest [2] could be
> pulled into the QGIS mac native library and used throughout QGIS.
> Nyall
> ( * I'm neither a mac user nor a fan of the touchbar concept, so aside
> from this heads-up I personally won't be pursuing this further)
More information about the QGIS-Developer mailing list
