[QGIS-Developer] Sort order for Value Map widget values
Tim Sutton tim at kartoza.com
Fri Mar 22 08:21:57 PDT 2019
Hi
> On 22 Mar 2019, at 15:04, Andreas Neumann <a.neumann at carto.net> wrote:
> Hi,
> The alternative (workaround) is to put your values in another table and link them through a shared key. Then the sorting works fine. Also the relation reference widget (which requires a relation) sorts values fine.
Yeah I tried that, the problem is I want to reference the lookup list from the same table:
Flowering_month -> months table
Fruiting_month -> months table
Pruning_month -> months table
If I try to use the relation system for that the months table is removed as a relatable table after it has been used once (another bug maybe)?
> Of course this doesn't mean the bug in the value map shouldn't be fixed. You can ask a developer familiar with the widgets (e.g. Matthias or someone else familiar with the widgets) to fix it, as part of our bug fixing program.
Yeah it would db great if you could fix that next time you are doing paid bug fixing @mathias - seems like a basic thing that should ‘just work’.
Thanks for the replies Giovanni and Andreas.
Regards
Tim
> Greetings,
> Andreas
> Am 22.03.19 um 15:26 schrieb Giovanni Manghi:
>> I am using a value map lookup to let the user select a month on a form. I used the ‘Load Data from Layer option and the months are displayed in a somewhat random looking order. Is there any trick to getting the values to display in ascending order of the key? Or is this a bug?
>> Hi Tim,
>> is a long standing bug.
>> cheers!
>> -- G --
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer <https://lists.osgeo.org/mailman/listinfo/qgis-developer>_______________________________________________
Tim Sutton
Co-founder: Kartoza
Ex Project chair: QGIS.org
Visit http://kartoza.com <http://kartoza.com/> to find out about open source:
Desktop GIS programming services
Geospatial web development
GIS Training
Consulting Services
Skype: timlinux
IRC: timlinux on #qgis at freenode.net
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190322/2c745042/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190322/2c745042/attachment-0001.jpg>
More information about the QGIS-Developer mailing list
