[QGIS-Developer] Calc default value or Reuse last entered value -bug ?
Lene Fischer lfi at ign.ku.dk
Sun Mar 24 23:30:53 PDT 2019
Stumbled into two problems – not sure how to solve:
Have setup an Attribute form and as a default value for area using ‘round($area,1)’ and ‘Apply default value on update’
While digitizing and want to reuse all attributes but the area – I have changed the Settings- Digitizing to ‘Reuse last entered attribute value’
Works fine for the first feature… but the second feature will then get the first features area value. I do know ‘You can´t get it all’ – but… I love to be able the reuse the no-calculated attributes AND get calculated values in the attribute form.
Second problem – Turning off the ‘Reuse last entered attribute value’ so there will be no conflict – I now wants to edit the shape of a feature. Using ‘Split feature’ from ‘Advanced digitizing tool’ I now have two features. Both have same attribute values except for the calculated value – as expected. BUT one of the features has the original area value. I expected to get both features attributes updated.
Any suggestions for my two problems
Lene Fischer
Lektor
Københavns Universitet
Institut for Geovidenskab og Naturforvaltning
SKOVSKOLEN
Nødebovej 77a
3480 Fredensborg
DIR 40115084
lfi at ign.ku.dk<mailto:lfi at ign.ku.dk>
[cid:image001.gif at 01D4E2DA.1D02AED0]
[cid:image002.png at 01D4E2DA.1D02AED0]<@Lene_Fischer>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190325/060e941c/attachment-0001.html>
Type: image/gif
Desc: image001.gif
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190325/060e941c/attachment-0001.gif>
Type: image/png
Desc: image002.png
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20190325/060e941c/attachment-0001.png>
More information about the QGIS-Developer mailing list
